Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 10-28-2010, 09:26 AM
jermu is on a distinguished road
4 x 4 Plasma table project
HI !
So here is another DIY plasma project (hopely lowcost). Working area is approx. 4 x4. 3 axel, i hope you get the idea from those pics (Z-movement is still under progress).
Do not hesitate to comment I appreciate all kind of comments.
Some specs:
Logic: PC, Smoothstepper and Mach3,
Electricity: Maybe Toroidal transformer,
Motors: three NEMA 23 steppers with Motion-drivers.
As you can see, I have planned motors inside the frame, atleast its fine with solidworks :P Those linear movements is executed with ballscrew. and supported with linear guides (like this http://www.designworldonline.com/upl...%20bushing.jpg ) Its pretty cheap,accurate and light.
Whats on your minds ?
ID:	117800   Click image for larger version
ID:	117801   Click image for larger version
ID:	117802   Click image for larger version
Old 11-02-2010, 02:28 AM
Dustin407 is on a distinguished road
Personally I would not recommend the ballscrew except for the z axis. Ballscrew and nuts are very expensive compared to other forms of movement. Plus the main reason is, I dont think you can attain the high speeds that plasma needs with thin gauge steel being cut... But if you intend to cut thicker plate it should work fine for you. The overall design looks good, keep in mind long hours of cut time those motors get pretty hot even hotter inside the tube...
Just IN- Precision Plasma LLC 2' x 3' DIY Plasma Table rchacich Product Announcements & Manufacturer News 9 08-25-2011 06:05 PM
Need help with rotary table project praetor Vertical Mill, Lathe Project Log 2 04-27-2010 06:58 AM
Just IN- Precision Plasma LLC 5' x 5' CNC Plasma Table rchacich Product Announcements & Manufacturer News 0 11-10-2009 10:08 AM
3x2m plasma table project/log bekx Plasma, EDM and other similar machine Project Log 56 05-06-2008 11:57 PM
5 x 10 table for plasma / tourch / router - project ajclay Plasma, EDM and other similar machine Project Log 29 03-20-2008 06:30 PM
