Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 10-04-2010, 07:16 PM
rockrunner86 is on a distinguished road
50 x 98" Plazma Table Build
I am currently working on a 50 x 98" plasma table. I picked the table up from a guy locally, he was in the middle of building it when some stuff came up. When I got ahold of it the frame was built, water table formed, linear rails and rack mounted to the frame. It came with a Blade Runner from Tom at Candcnc as well. The X and Y axis are running on 25mm linear rails. The Gantry is a piece of 80 x 160mm extrusion, and it is equiped with a K2 torch height unit.
I have built everything from the main table rails up, some of the parts are still just for mock-up. I am starting to get really excited to get it up and running. Still trying to decided on a plasma for the table. I am of the buy it once thinking so I am going to get a big machine, so far I am thinking Thermal Dynamics A120 or the Hypertherm Powermax 85.
I am also seriously thinking about adding a second linear rail on the gantry. Also the gantry is driven from both sides but I don't have both sides on currently. Tonight I am going to try to get the final side plates cut out for the belt reductions for both sides of the gantry.
Once I get it finished I am going to move it to the larger size of the shop, where I intend to build a room for it.
Here are some pictures of it as of now.
Old 10-05-2010, 08:04 AM
ric812 is on a distinguished road
What is the table bed made from? It looks like fiberglass
Old 10-05-2010, 09:43 AM
The bed is made of Alum. sheet it is broke on the two long edges and I am going to weld in the ends plates shortly. It has a bunch of build up from sitting in the shop so long, mostly dust from cutting copper..
Old 10-05-2010, 10:29 AM
Thanks for the fast reply and good luck with the table it look really nice
Old 10-18-2010, 06:29 PM
Its running. Not dialed in completely yet, and I still have alot of work to do. However, seeing it move under its own power yesterday was great.
I have a little more wiring to get done, a few home and limit switches to finish up. I also need to replace a bronze bushing tomorrow when it arrives. I some how killed a pivot pushing for one of the motor side plates when pushing it into the bore. I quickly turned a aluminum bushing to get by for the day.
I currently have the motor controls setup for all axis to the correct steps per inch and have compared the movement on the DRO to measurements and I am dead nuts on.. Needless to say I am pretty excited.
I think I found a Powermax 85 with machine torch instock, going to make a few calls tomorrow, if I can locate one its on the way...
Old 10-20-2010, 11:51 AM
Well I just placed my order for a Hypermax Powermax 85 with machine torch. Can't wait for it to arrive.
Old 11-05-2010, 12:38 AM
I finished up the torch mount tonight, everything is running and ready. Well at least as far as I can go until my Powermax 85 shows up from Hypertherm.
Old 11-05-2010, 10:42 PM
Boogiemanz1 is on a distinguished road
Looks like you are getting close. Lots of nice parts. Is your K2 axis a 6"? anything you would have done differently? Thanks for sharing........jb
Old 11-06-2010, 04:42 AM
Ya, I think I am really close, just need the darn plasma cutter to show up. Keep getting told a shipping date then delays...
Things I would do different.. I would mount the linear rails on the inside of the steel frame, I would weld the steel frame together rather than the bolted plates, I would of made the table at least 8' x 14', I would of used the biggest servo motors Candcnc has on x and y.
Given that I bought the table partly completed, with the electronics for a great deal I am very happy. Knowing myself I will be building a new table with all the items I listed shortly.
I haven't decided which I am going to add to this table, but I am going to be adding either a air scribe or a air spindle as soon as the plasma itself is running. I am leaning to adding a the air spindle, as I have some applications where it would be nice to be able to drill some smaller (1/4" or smaller) holes.
Thank you for the comments..
New Machine Build- 60"x60"x16" Build from stuff I have laying around whiteriver CNC Wood Router Project Log 25 01-28-2011 02:38 PM
Newbie- First build 8020 60"x24"x5" Board Shaper dlyork DIY-CNC Router Table Machines 18 09-07-2010 08:32 AM
New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105 Modular CNC Open Source CNC Machine Designs 0 11-08-2009 11:36 AM
Had You built CNC Plazma at home. sanjiv CNC Plasma and Waterjet Machines 1 01-10-2007 10:44 AM
