| Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss. |
Hey Guys new here... Machinist Fabricator... Just started my build of a Precision Plasma gantry system, with a Bladerunner Dragon cut . Here is what I have so far.. Table material ordered and Delivered Gantry system ordered and delivered Still waiting on Stuff from Tom at CandCNC Specs BladeRunner AIO Controller with 4 Drives (4 axis) 576W 48V12A Power Supply 4ea 300 oz-in 3.5A Hybrid Stepper motors - optimized for the BladeRunner THC Sensor Card & cable DTHC Expansion Module - Installed Full Cable Set DTHC I upgraded my system to the 5th axis and 620oz motors Dragon-Cut 620-5 ROTARY (5 MOTOR) DRAGON CUT w/Rotary Wizard and TubeSlicer(tm) Basic 5ea 620 oz-in motors Here is the pictures of the table build. so far pc's cut to 4) 56" 2) 48" 4) 44" 4) 7.5" 4) 26" ![]() I removed my 3/16" top from my blanchard ground table so I could be realy anal and get everything square and true ![]() My table is that much out on the floor so close enough Last edited by rock4xfab; 07-02-2010 at 04:40 PM. |
| Sides done and bottom square migd in. It took awhile to square it up by myself but it is dead on. The 2x3 you see clamped is to hold the side upright and to help keep them from warping in or out ward. What is not in the picture was the big ass Machinist angle plate that was clamped in the mix also. ![]() ![]() |
Thank you, Welding is my main source of income along with the machining.. Generaly under a helmet of 14 hrs a day. So you either get good or get out. LOL |
| Some stuff most of you have already seen.. If I get a free moment this afternoon I will try and post my Table drawings... V-Rail and rack along with pulleys and Ugraded Z-axis The z-axis is a finer acme 5 turns to and inch vs. 10 turns ![]() ![]() ![]() And for those that like pretty welds here is a teaser ![]() Last edited by rock4xfab; 07-02-2010 at 11:10 AM. |
I have been super busy but I have a few updates I will post up later tonight... All my electronics have shown up, and the rails are mounted and I have the gantry trued up... I still have to source the E-track and then disasemble for powder coat and build my water table... |
#10
| OK here is what I have done so far...and some may have been overkill. but I have equipment to perform the tasks.. I set my table sides up in the mill and drilled them for the rails... Now it was recommneded to use .063 wall tube and drill tap for .25 srcews.. I used .083wall tube and I drilled my top tubes for .4 hole. Then drilled and tapped a pc of 3/6" plate 3.15" or 80mm on center to use .3125 button head SS screws all 15 holes. I then mounted the gantry rails, to the frame, squared them and set the V-rollers, I think .7 on one side and .9 on the other. Not exactly center but the adjustment lets the gantry foat, and I have full contact on the gear rack. I then mounted all the motors and belt drives ( actualy a couple times) I put the carage in front of the horse and had to dissasemble and redue. I drilled all the 620oz motors out to .1875 to allow the supplied screrws to be used. After all the motors were hooked up I started looking at the next step. Cable routing and e track... I just ordered My cabel track from Mcmaster on fri, it should be here Tuesday. Once I have that I will bend up some aluminum channel I am using .040 but it wll be dimple holed and flared to give rigidity... Anyway here are a few photos.. Also for those using the presicion plasma gantry kit( non bolt together..) Hole spacing on the rails is 3.15 or 80mm total holes for the 3x4 kit is 15 per rail. Hole diameter .35 Also thank you to unixadm for giving me the Part numbers he used for the Cable track I ordered 2-6 foot pcs and will make them fit my use. 1 4409T513 2 Each Open Hinged Cable And Hose Carrier, 0.98"h X 1.50"w Interior Size,2.17"bend Radius,6'l 2 4556T562 2 Pairs Mounting Bracket For Cable And Hose Carrier, Open, For 0.98"h X 1.50"w ![]() ![]() ![]() Hard to see but inside the rail is the 3/16" drilled and tapped plate that the rails are bolted into. |
#11
Awesome build. Alot of attention to detail here. 2 questions: What did you use to cut your steel. Those are very clean cuts! Cold saw?, Band saw? Can I ask where you bought this gantry kit? Link? |
#12
| The Gantry Kit is from Ron at Precision plasma...All my electronics are from Tom @CandCNC.com I went with the Dragon cut 5 axis as I will be adding the Rotory head by prescion plasma, at some point. http://www.precisionplasmallc.com/ |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-07-2011 11:16 PM |
| My 4x4 Plasma Table Build | unixadm | Plasma, EDM and other similar machine Project Log | 8 | 06-19-2010 11:51 PM |
| new plasma table build | miles peters | CNCzone Club House | 0 | 06-16-2010 10:20 PM |
| I want someone here to build me a plasma table | carbidecraters | CNC Plasma and Waterjet Machines | 3 | 03-08-2006 05:27 PM |
