Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 03-28-2010, 10:30 AM
deltaguy23 is on a distinguished road
torchmate 2x2 water table fab
I just purchased a torchmate 2x2 and I want to build a water table to place under my machine" can anyone out there give me some technical advice or a set of drawings so I can put something together I would greatly appreciate it!
Old 03-28-2010, 01:52 PM
millman52's Avatar
millman52 is on a distinguished road
Not familiar of the 2 X 2 design other than what I see in the TM Advertisement. About all you need to do is build a square pan from 12 or 14 gage material that will fit inside the frame.
Build it so the slats can be easily removed to muck out the pan when needed. The pan probably needs to be apx. 4" deep.
Small table I'm assuming small parts. I'd place the slats no more than 2" apart or even closer to prevent part tip ups. A close slat grid may prevent you from crashing the plasma torch into a tipped up part.
If you are going to have a holding tank to drain the pan & refill when you use the table. you will need about a 15 gal. tank for that.
If it works.....Don't fix it!
Old 03-28-2010, 08:04 PM
jimcolt is on a distinguished road
Look on the www.pirate4x4.com site....there is at least one guy building one there with pictures, etc. A lot of Torchmate people on that site!
Actually....I think this link will get you right to the thread http://www.pirate4x4.com/forum/showthread.php?t=870411
Jim
New Torchmate Table Build runninwild400 Torchmate 8 07-11-2008 05:50 AM
Need Help!- Does anybody know what to mix in the water, on a water table? suzukirmz CNC Plasma and Waterjet Machines 8 06-21-2008 11:56 PM
DYNA CNC TABLE WITH WATER TABLE DISCONNECTED CNC Plasma and Waterjet Machines 0 06-06-2008 08:04 PM
Torchmate, 4x4 table slats balto Torchmate 3 08-10-2007 09:45 AM
Water transfer techniques for water table? Knut CNC Plasma and Waterjet Machines 3 02-02-2007 09:52 AM
