Need Help! HYPERTHERM Powermax45
Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: HYPERTHERM Powermax45
    Registered tulsaturbo's Avatar
    Feb 2008
    Default HYPERTHERM Powermax45
    I almost have my table finished. All that is left to do is finish making the table bed. So I borrowed my buddies 40 amp plasma cutter which he got from harbor-freight for testing purposes. I had to rig the torch switch with leads to activate the cutting torch. Everything worked fantastic. I was cutting 1/8" steel. I was very happy with the way my machine is working. The chinese trafimet plasma cutter did very well and seemed to be a very nice unit but I want long term reliability and want to stay with american made products.
    So here is my question:
    I just purchased a powermax45 handtorch model that was onsale today. I'm tight on funds and could not afford the machine torch setup with the cnc pendant for activation. I know that the powermax45 has a rear machine interface and would like to know how most of you have connected it to your cnc machines for torch activation. I am not running any type of THC system just a floating Z head for height control. Did most of you go with rigging the switch or using the machine interface port and if using the machine interface - how is it done?
    Thanks in advance!
    VIDEO: "http://www.youtube.com/watch?v=XJ-5KdZ3mCw"]YouTube - Trafimet CNC Torch Test
    Gold Member
    Jan 2008
    The machine interface port will only work if you are using a machine torch...it is inactive if the hand torch is plugged in......this is for safety reasons.....and there is a long story behind it that involves an acetylene cylinder and a building burning down.
    If you need to use the hand torch with a remote start...such as the output of your machine...you will need to either splice into the trigger switch wires inside the torch....or inside the power supply. They are relatively easy to trace...but as a Hypertherm employee...for product liability reasons I cannot help you do this.....sorry.
    Jim
    Feb 2008
    Quote Originally Posted by jimcolt View Post
    Jim
    Thanks for the prompt reply Jim. I understand your position as an employee. Maybe someone else can chime in with their setup...
    Dec 2004
    Surrey BC Canada
    i have the images for 1000 or 1250 but im not sure if the wiring are the same as for hypertherm 45
    i basically moved the pins to make it work..
    t60h.gif = hand torch
    t60m.gif = machine torch
    hope that helps
    Attached Thumbnails Attached Thumbnails HYPERTHERM Powermax45-t60h-gif   HYPERTHERM Powermax45-t60m-gif
    Sep 2005
    Indonesia
    Hello Jimcolt,
    Can we use hypertherm machine torch to miller machine torch or vise versa? In other word, one brand machine torch is specific. Only use the same brand. How about consumable items, are they brand specific, can not use different brand. Thanks. Asuratman.
    Gold Member
    Jan 2008
    Hypertherm manufactures Miller's torches.....to Millers specifications. They use different consumables and have different connections. It would not be easy to switch from one to the other, and consumables are not interchangeable.
    Jim
  7. #7
    Feb 2008
    Thanks DanOSB!
    Those pinout diagrams for the torch help out a bunch. So I'm going to assume that pin #10 on the handtorch is moved to position 9 with the trigger kept in the engaged position. I'm thinking probably pin #7 has to be moved to position 8 as well. All that remains is to figure out which 2 pins in the rear machine interface plug will activate the torch. I'm thinking its pin #3 and #4 but at the moment I'm not sure...
  8. #8
    Gold Member
    Jan 2008
    Pins 3 and 4 on the interface plug are start inputs.....with the machine torch connected...if you short 3 and 4 the torch will fire. The torch for the 45 is a totally different design as compared to the 1000/1250/1650 torches.....so trace the trigger wires carefully.....there is also a "parts in place" microswitch inside the torch handle to confuse matters!
  9. #9
    Feb 2008
    Are you refering to the cap_sensor switch as the "parts in place" microswitch?
    Also is it possible to get a pinout diagram for the T45 machine and handtorch like the ones posted by DanOSB for the T60?
    Man I wish I still had my buddies Trafimet plasma cutter... He's not in town right now and need to cut some parts today so I'm stuck until I get this figured out... I know I can just splice the switch on the handle to get this to work as I've done before but I really wanted to refrain from that method.
  10. #10
    Gold Member
    Jan 2008
    Parts in place sensor and cap sensor are the same. The manual lists the pinouts for the rear panel connector.....and shows an exploded view of the torch assembly....including the trigger switch and the cap sensor switch. I would just trace the trigger switch wires back to the plug end of the torch....then follow the plug inside the power supply and make my start connections there.
    Jim
  11. #11
    Aug 2008
    Hey Jim;
    What does the "parts in place" switch do ??
    Is it to make sure the comsumables are in proper location?
    I'm getting my 45 hopefully by weeks end !!
  12. #12
    Gold Member
    Jan 2008
    Yes....the "parts in place" switch, also known as the "cap sensor switch" ensures that the consumable parts are properly inserted.....and helps to ensure that the torch power can not be active when you are changing consumables.....safety.
    You will not regret buying the 45.....but you should go lock up all of the valuable pieces of metal in your shop.....most of us have been known to go on a plasma cutting frenzy shortly after unpacking the new Powermax unit...
    Jim
