I would highly recommend Hypertherm.
Initially I had the ForceCut 80i on the table I built/am building (thread:
http://www.cnczone.com/forums/plasma...nc_plasma.html ). Now I am running a Hypertherm Powermax 85.
The Longevity works just fine for a handheld system but (in my experience) is a real pain on a CNC table.
For starters, the raw arc volts output on the CNC plug weren't correct, I had to go into the machine and bypass the "CNC board" to get the real arc volts.
Also, the arc ok/arc Xfer signal comes on when the pilot arc fires, not when the arc is actually transferred to the workpiece. This can lead to motion occurring a little too early. Sometimes it would send out the arc ok signal when the torch didn't even fire.
I also had problems with the 80i not extinguishing the arc once the arc off signal was sent, so the torch would keep firing on the way to the next cut and then shut off when it got the arc on signal to start the next cut.
Further, the "machine torch" for the 80i is some oddball shape that doesn't fit any standard torch holders, and is rather difficult to make a custom holder for. The "machine torch" also has a trigger/switch on it for no apparent reason.
The 80i also uses only unshielded consumables. This means that the first time a part tips up and hits the tip of the torch while it is firing (this is very common) you will get double arcing that damages the tip so it will not cut straight. I was going through tips at about the same rate that 105mm howitzer shells were used be used during the first few hours of the Battle of the Bulge.
Finally, the 80i uses high frequency starting that puts out enough interference that it can, and probably will, play merry hell with your electronics. I had to completely disable my emergency stop inputs just to keep the table controller from stopping every other time the torch fired, even though I grounded it according to recommendations.
Since switching to the Hypertherm 85 I haven't had any issues with high-frequency interference because it used a blow-back start method instead of HF. The Hypertherm can also uses shielded consumables so tip-ups don't damage the tip/nozzle. On my first set of consumables (65 amp) I produced more than 300 parts with well over 700 pierces from 3/16" - 3/8" steel and 1/4" aluminum. Of all those parts, I can think of only 3 times when the torch failed to fire, and tat was at the end of the life of that consumable set.
Since you will mostly be doing thin aluminum and steel I think a Hypertherm Powermax 45 (smaller version of the 85) would work nicely for you.
Also, highly recommended using a real machine torch, instead of trying to save a few bucks by modifying or hacking a hand torch to work under CNC control.
