Results 1 to 2 of 2
Thread: Stepper shakes when it normally stand still
    Jan 2007
    Belgium
    Hello,
    I use 3 picstep drivers for my CNC machine. They have done their work very well! But when i started my machine today my Z-axis stepper was shaking. And is not turning correctly.
    I don't have a scope at home but when I touch the switches wich set the stepmode the shaking stops, and returns after a while or when u want to move the motor.
    But when i measure out that circuit nothing abnormal shows up...
    could it be a LMD thats damaged? I use 8k for the current resistor.
    Registered budP's Avatar
    May 2008
    My take on this is when you have a problem and you can touch, push or move a component or wire and it changes the problem it is probably a bad solder joint.
    budP
  1. Need Help!- Stand alone encoder controlled stepper driver
    By JWWalthall in forum Open Source Controller Boards
    Last Post: 10-10-2008, 01:28 PM
  2. 5-phase Stepper/Driver users please stand up.
    By Konstantin in forum General Electronics Discussion
    Last Post: 06-19-2008, 12:35 PM
  3. So what does TLO stand for?
    By CNCadmin in forum FAQ of CNC Machine building
    Last Post: 10-23-2004, 06:07 PM
  4. What does CAD/CAM stand for?
    By ynneb in forum FAQ of CNC Machine building
    Last Post: 08-16-2004, 07:40 PM
  5. What does CNC stand for?
    Last Post: 08-16-2004, 04:31 PM
