Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PicStep Controllers
PicStep Controllers Discuss PicStep Controllers here!
Old 11-28-2006, 02:09 AM
Cooper is on a distinguished road
Power Supply for PicStep
Dear All,
I'm newbie at stepper motors and picstep. I'd like to drive 3 stepper motors with PicStep. I prepared 3 Picstep and i need to choose powersupply. My motors are :
http://www.kelinginc.net/KL23H276-30-8B.pdf
Keling 280 oz-inch Nema23 8 Wires 3V 3A. So, what kind of power supply should i select? What do you advice? Voltage, Amps, classic or smps? (Toroid is difficult to find for me )
Thanks in advance,
Cooper
Old 11-29-2006, 01:22 PM
dtman2 is on a distinguished road
I am in exactly the same situation - same motors and same driver board. SMPS runs well over $100 once you get into the higher voltages unless you can scrounge something. A hammond 165S25 25V 10A transformer runs $86 at Newark, then add bridge plus filter caps plus chassis. That is 115V primary though - what is the mains voltage where you are? Toroidal transformers are not really necessary, they are mostly just smaller and lighter. I am going to start with three 12V 10A/h lead acid cells that I have kicking around in series, with a small 1A charger, which should be able to run for a few hours. I will worry about a proper PS later.
Old 11-29-2006, 11:56 PM
vladdy's Avatar
vladdy is on a distinguished road
I've had good luck scrounging at the local scrapyard..
for example, a used electric forklift battery charger, 24v @20a, complete with switches and enclosure was $10 [Canadian yet..]
enjoy..
