Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PicStep Controllers
PicStep Controllers Discuss PicStep Controllers here!
Old 08-03-2006, 09:41 AM
PsyKotyk is on a distinguished road
PICStep clone with Eagle files
I was getting seriously frustrated at trying to get the PICStep gerber file into Eagle for milling purposes, so I did my own rewrite. Similar connections, with a small modification on the motor output terminal block (for unipolar convience)
Also, the current limiting oscilators have a 10turn pot for adjusting.
This is sort of a mash up of Alan's awesome design and the equally excellent EAS design. For firmware, use Alan's code.
BE WARNED: I have not built or tested this design yet. It *should* be okay, but who knows. No warranty implied or expressed.
Included are the Eagle library files for the LMD18245 and PIC16F62x. They need to go into the eagle "lbr" directory.
If you make improvements or corrections, please post them back here on CNCZone.
Old 08-03-2006, 04:00 PM
pminmo's Avatar
pminmo is on a distinguished road
Nice job! If your wanting to be easily compatable with the open source stuff, SV1 is out 180 degrees. http://pminmo.com/interface.htm Still works you just need to remember to twist the cable once.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 08-03-2006, 04:12 PM
pminmo's Avatar
OOP's you have a couple of gotcha's. DAC ref, Capacitor physical sizing on the electrolytics maybe an issue. 78L05Z issues, input voltage, power.
Old 08-08-2006, 11:34 AM
Ahh good points. I'll drop the regulator all together. The interface board can deal with that.
Old 08-08-2006, 12:28 PM
pminmo's Avatar
It's a good idea to handle the 5V, but use a to220 sot223 or to252 package.
Your 1uf package is to big and the 470 to small with at 63vdc.
Old 08-09-2006, 09:57 AM
Here's a rev with the 7805 removed. I haven't resized the caps yet, as I'm still waiting for my parts to arrive, at which point I'll take some real world measurements.
This version includes Alan's latest firmware (2.0), the GPL license and a README with the various "may asplode in your face" warnings.
Old 08-21-2006, 04:48 PM
I've gone ahead and changed the capacitor sizes to match the 390uF 63V ones I got from b.g. micro.
Also made the traces thicker to aid production methods like milling or glossy-paper + toner transfer.
Still haven't done a trial of this board yet, so builder beware.
Old 08-24-2006, 01:52 PM
Moved the input signal connector to allow more space near the board mount holes. Also allows for keyed connectors.
I've finally gotten a board made and all the parts, so we'll know real soon if it's a keeper.
Old 09-02-2006, 05:28 PM
Here's a working revision. I strongly recommend not building any previous revision. The 20K pot in parrallel with the 6.6K resistor is dangerous. I've changed them to be in series which should protect the LMD from going beyond its limits.
Had lots of issues with crystal resonance. Added a series resistor as recommended per the 16F628 datasheet. Also added a noise reducing capacitor across the +5V. This made a huge difference in how cleanly it ran, and at what speeds it would step.
Old 09-07-2006, 08:08 PM
New release with some cosmetic board changes. This ensures that all traces are separated by at least 1mm (for easier milling with a wider bit).
Added a few more fill areas to save on etchant/milling time (if you enable that).
The picture below (not to scale, so don't use it directly for making a board) was touched up in Gimp, than tiled so there were 6 on a sheet, and then printed back to postscript, ready for toner xfer.
  #11   Ban this user!
Old 09-08-2006, 02:19 PM
opcode1300 is on a distinguished road
im new to all of this. but do you have a parts list? digikey or mouser?
thanks a lot.
  #12   Ban this user!
Old 09-13-2006, 05:03 PM
thanks a lot.
I used to until my laptop hard drive decided to take a dirt nap yesterday.
I'll try to put one together this week. A lot of them you can find off the EAS website (see the first post in this thread). I picked up the capacitors, crystals and some other parts from B.G. Micro for quite cheap. They also have the PIC's for cheaper than Digikey, but are sometimes back ordered.
