Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PicStep Controllers
PicStep Controllers Discuss PicStep Controllers here!
  #13   Ban this user!
Old 09-17-2006, 12:12 PM
PsyKotyk is on a distinguished road
Just a final follow up. I tried using some different crystals I found at the local Computer Recyclers (2 for $3 yay!), and things started working perfectly. I must have been using some non-parallel cut x-tals. These ones were in the tall can instead of the short one.
The resistor in series with OSC2 can be ommitted completely, so either jumper it, or edit the schematic/layout, or just cover the gap with a sharpie if using toner x-fer.
I had a successful test at 52V (the stepper was certainly moving quickly), but when I touched the heatsink to check the temperature, I felt a definite surge of voltage. I thought the heatsink was supposed to be GND?
Anyone tried liquid cooling for their heatsinks?
  #14   Ban this user!
Old 09-18-2006, 08:39 PM
opcode1300 is on a distinguished road
when i get my HF mill up and running i was gonna run some copper waterblocks to get it setup and to help w/ cooling.
but i keep smoking my xylotex board, so i gotta get some diffrent motors to try.
  #15   Ban this user!
Old 10-09-2006, 10:56 PM
tfmacz is on a distinguished road
Smile My PICStep controller
I thought I would share a couple pictures of My PICStep Controller.
I am a fan of pcb milling and cut one of PsyKotyk's boards except I put the 5V reg back on the board as my system needs it there.
I am running a tripple stack NEMA 23 stepper at 2.8A so need the big heatsink.
Thanks Alan for the code to make this run.
ID:	23959   Click image for larger version
ID:	23960   Click image for larger version
  #16   Ban this user!
Old 11-06-2006, 12:59 AM
PICStep V4.0 Board and Eagle files
Here is my version of Alan's board Have a working board. Works great.
I am salvaging 20mhz crystals off of old 10meg ISA network cards. so far I have not had any that did not work.
  #17   Ban this user!
Old 02-05-2007, 10:51 AM
Xephius is on a distinguished road
Hi all. I have all the components to build 3-4 boards for my new CNC machine. Would anyone be willing to knock out the PCB's for me? I am happy to pay for them, and I know that I can buy the PicStep boards (probably the same price or cheaper) but I would rather work with Open Source works. The project looks great, I hope I can be part of it.
-John
  #18   Ban this user!
Old 02-05-2007, 12:27 PM
pminmo's Avatar
pminmo is on a distinguished road
Which version? I'd be willing to as I've finally got my pcb cycle pretty well tuned. Plus I could add the code to my website.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
  #19   Ban this user!
Old 02-05-2007, 12:44 PM
PMINMO,
Thanks so much. I would like to use PsyKotyk's latest board revision. Using a external 5V regulated powersupply is not a probelm for my setup. You can contact me directly at jc (at) xephius (dot) com. I look forward to working with you.
-John
  #20   Ban this user!
Old 03-20-2007, 03:05 PM
sdantonio's Avatar
sdantonio is on a distinguished road
I just got my CNC router finished as of Sunday night and I'm already looking at modifications, such as new driver boards. I was looking at your set of gcode files. Could you elaborate a little on how you would go about setting up a board for routing, registration points, which NC files to use and in which order. Size of router bits and drill sizes etc. Hopefully, with a little bit of explaination and if I look at things long enough then it will begin to make sense.
If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
Steven
