| PicStep Controllers Discuss PicStep Controllers here! |
A lot of chopping driver chips don't directly support microstepping, however it can be done by varying the VREF input. I made a simple circuit using a R2R DAC and a voltage follower between the PIC outputs and the VREF input of TEA3718 chips (used these TEA's because I had them here), it's working fine. Below is the basic diagram. With this it's possible to use recuperated or cheaper chips than those quite expensive LMD's. If there's an interest I can make up the complete schematic and post it in the open forum. There are no modifications needed to the PICSTEP firmware. Alan, do you have objections or comments? Luc. |
| I've also considered these "poor man DAC's". They should be every bit accurate enough for the application. I just got a sample tube of 18200's, but they're only a buck or so cheaper than the 18245's. I'm thinking discrete is the way to go.
__________________ Steve DO SOMETHING, EVEN IF IT'S WRONG! |
http://www.semiconwell.com/r_net/swr2r04a.htm For CNC microstepping is in most cases not used to increase resolution but to smooth out the motor, so tolerance isn't a big issue: just have a look at the step tolerance of a typical stepper..... I use industry standard 1% resistors from the same batch and use 2 in series to make up the 2R values, this should be more than good enough. My next project could be a high current driver using mosfet's and the L6506 (or similar) for the chopping part of it. Edit: I misinterpreted your reply, you were saying that this is accurate enough, sorry. I will leave this for those who have doubts. |
| Have you done the code for your poor man's dac?
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
Alan did a good job.
| Hi, Sorry for repeating myself, but are you going to upload the full schematics as you said: "If there's an interest I can make up the complete schematic and post it in the open forum." I am interested to try your solution. Thank you. Zoltan |
| Zoltan, no problem, just needed a bit of time to complete the schematics. So here we go: http://www.cnczone.com/forums/showth...567#post181567 Feedback appreciated. Regards, Luc. |
| I never analyzed the LMD DAC, I tought it was like allegro's 3 bit non linear dacs, I see that isn't true now. I'm missing something though, I did some calculations and the 4 bit dac of the lmd and it looks like it has as much as 5% error when quarterstepping? How are people doing 1/16th micro stepping with it?
#10
| Phil, like you I never looked into the details of the DAC's usage nor their "error" or the respective results. I simply use the PICSTEP firmware and it gives wonderfull results. 5 % of one quarterstep (= 0.25/step) is only 0.0125/step, this doesn't look really important for our applications. How they do 1/16th: just to smooth the motor's movement, certainly not to perfectly increase the resolution to exactly 1/16th with 1% precision. Must say that I didn't try 1/16 yet, the new firmware wasn't available at that time. A stepper motor has a bigger tolerance problem per step than this. If my memory serves me right, Mariss, Gerry and others have pointed this out several times, microstepping doesn't increase resolution. Regards, Luc. . |
#11
| Yes I understand the increased resolution/accuracy issue, just wanted to point it out if anyone was thinking along those lines.
