Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: New PICStep firmware available
    Registered Garfield2's Avatar
    Sep 2004
    PICStep now has a V2.0 firmware available.
    It has a new 1/16 mode (1/16, 1/8, 1/4 and 1/2, lost full), a 5 1/2 minute auto shutdown and the direction line bug fix.
    The motor should sound exactly the same in either direction.
    http://www.fromorbit.com/projects/picstep/
    Alan.
    Mar 2005
    Romania
    Thank you.
    Zoltan
    Jan 2005
    Where is the v.2 software listed on the site? all i can see is v1.1
    Apr 2006
    PICStep gets 1/16 stepping and a bug fix! 25/07/06
    After deciphering what RadekCX from the Czech Republic was on about in numerous hard to understand posts on CNCZone, I finally figure out what he was talking about. He had found a bug in the firmware that was caused by a bug in the LMD18245 datasheet.
    The LMD will not switch correctly if the direction of the energy flowing through the coil changes before the LMD DAC is told to go to 0 (it must be 0 before the direction change). A tweak of the firmware and some tidy-ups and this issue is now resolved. The motor should sound exactly the same in both directions of rotation (and may have less resonance at high speed).
    I've also added 1/16 stepping because I was rewritting the DAC tables anyhow and it seems like a nice little upgrade. The mode switches now select from 1/2, 1/4, 1/8 and 1/16. So if you liked the 1/8 mode you will need to adjust you mode settings to keep it as it will now be 1/16 otherwise.
    Also I've made two versions for the compiled HEX files. One with the auto 5 1/2 minute shutdown and one without for those that hated the shutdown feature.
    Let me know if you find any more bugs!
    * NEW Firmware V2.0 20MHz - Sources + HEX
    * NEW Firmware V2.0 (No auto timeout) 20MHz - Sources + HEX
    i think something happened to his hosting.
    Jan 2005
    Cool thanks,
    What setting is torque compensation on? 1/2 step?
    Feb 2006
    A while back I ran into an issue with the 16F628A not programing properly.
    I don't remember the issue. We were using firmware designed for the 16F627 as I recall and there was something different about the 16F628A that would not work.
    Does this code work in the current 16F628A? Microchip is only offering samples on the A versions of the pdip package.
    Jan 2005
    I'm currently running the 2.0 firmware on my 16F628A didn't have any programming issues, using mplab icd2
    Feb 2006
    I do not seem to be able to get it to change micro step mode???
    The jumpers hace no effect???
    In the source there is only one dac table for 1/16 mode
    I really need this thing to 1/4 step.
    Sep 2006
    Serbia
    Quote Originally Posted by tfmacz View Post
    Did you try manualu, step-by-step? If using GCODE speed can be to fast to see difference, but with jog difference is so obviously.
    Feb 2006
    Smile Non Auto Timeout Version BRoken???
    If the drive is in the correct mode a move of one inch should result in the same number of revolutions as the pitch of the lead screw and the carradge should move one inch.
    on this machine a 1 inch move should result in 10 revolutins of the lead screw. I was only getting 2 1/2 revs.
    As it turns out I was trying the "Non Auto Timeout" version. I tried the "Auto Timeout" version and it works properly, so possibly the "Non Auto Timeout" version is broken.
    Thanks for your suggeston though.
    Ted
    Sep 2006
    Serbia
    Ted
    Yes, I just tried with "Non Auto Timeout" and it didn't work. I.e. works, but has only one mode - 1/16 and jumpers has no effects.
    ASM codes are the same for both SW, except line 23 #define TIMEOUT_ENABLED and it is normal.
    In any case, I like "Auto Timeoutcode", but I will be really happy if Alan will be so kindly to tell me how to change timeout from 5.1/2 minutes. I didn't know assembler well so I can't find "magic value" in code.
    Sep 2004
    Quote Originally Posted by kodalo View Post
    I'll have a look at that, the defines are probably hiding something they're not suppose too. Since I never use the non-timeout version I don't really test it to fully
    It's done using the 16 bit TMR and a few overflow registers. There isn't really a magic number to keep the code fast.
    Code:
    	incf		timeout_reg, f		; Increase the timeout reg value
    	btfss		timeout_reg, 2  	; Check we've been around the 4 times of the 16 bit counter (~5 minutes 45 seconds @ 20MHz)
    	  goto		Loop
    Comment out these lines to reduce the timeout to like 70secs or change "timeout_reg, 2" to some other bit field number (ie. 0-7) to increase the time. Experimentation is the key (else crack out the calculator and use the number of instructions versus the clock frequency to get an exact time)
    -A.
  • Page 1 of 2 12 LastLast
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
