| PicStep Controllers Discuss PicStep Controllers here! |
Hello, I made PICstep driver with FW with torque compensation but this SW not work. FW without compensation worked but if I testing max rpm i working gut only one side rotation. I write my own FW. I lost many months development, because bug is mainly in datasheet for LMD18245. Very difficult is timing algoritmus for generating outputs for bridge. Unfortunately my driver is comercial project and I cant public source code for PIC16F628. My driver is public on my web http://www.cncnet.info/view.php?naze...nku=2006050002 Parameters Bistep: ------------------------------- microstepping: 1/2 1/4 1/8 1/16 for step input frequence: 45kHz optocouplers on inputs compatible directly with LPT current settings: 0.5 - 3A step 0.5A DC supply: 12-48V...driver has on board step-down converter for 5V logic timeout: is not implemented By testing this driver with bipolar motor 3V/1.5A rotate above 1500rpm with full strong. Pinout PIC16F628A with my FW is compatible with original version Picstep. RadekCX |
If english isn't your strongest language please don't confuse your post with acronyms.
Alan. |
| What language is the webpage? is there a compatable english translation page?
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
I need fom may CNC drivers and PICstep was very nice and I working with PIC MCU. I made my own version PCB and flash FW version with torque compensation. This version not worked. I flash version without compensation - this version worked ( seemingly). But I need microstepping 1/16. I rewrite your FW new. No with ASM but I use mikroPascal for PIC. This FW worked as your FW - have extra only 1/16 microstepping and not support full step. This version FW and PCB is on my website http://www.cncnet.info/view.php?naze...nku=2005120802 with all source code, HEX and all documentation. But when I this version testing I find bug see above. What to do!!! I have four PCB and bad working. I flash again your FW and when I thoroughly test have aqual bug as my FW. I again and again rewrite FW and testing but driver not work well. But I finaly uncover why driver not working OK. This bug is already in datasheet LMD18245. This argument for equal pinout on MCU. Then I made new PCB with DC-DC converter and this project is Bistep. PCB not equal with Picstep, FW is not equal with Picstep - only pinout is identicaly with Picstep. My new HEX have 7.5kB - almost 2x better as PICstep. Is this violation GPL - IMHO NOT!!! Any driver with PIC16F628, LMD18245 is PICstep? Sorry for may english - better I dont know. RadekCX |
The coil currents are simply a look-up table output to the DAC of the LMD's. There really isn't much to go wrong here as far as my reading of the datasheet.
But at the same time, you cannot cry "WOLF WOLF" about my firmware without showing where this "bug" is. That's just not very nice to the community that has "helped" you produce your "commercial" firmware. Alan. |
I have two diferent version PCB and result is every equal - bad rotation (resonance, not max rpm) on one side not dependent on subtitution coil on motor (this eliminate bug in motor). When I write first version my FW was equal problem. When I flash new FW in both PCB then all problems lost.
Before many weeks I write second email - here I write about the bug in our FW. On my emails you do not replied. Maybe in this time was possibly cooperation. Then I posted message in this forum. Alan don't cry now! How community "helped" produce my version FW!!!?? Schematic PICstep is identicaly with recommended schematic in DS LMD18245. Is it not new. New my FW is absolutely different. Driver Bistep now completed company not dependent on me and I cannot FW release. I have not obligation to community!! Information about bug you know now. It's all. RadekCX |
| Still note: On my web is most projects free and people can download all documents free - I not need GPL - its simply free - for example weatherstation with web output, LCD with RS232 input and other. I working as devoleper SW for PC and working with MCU is my hobby. When I get any money from donate or when I sell any project with MCU, then I put profit from this projects into SW or instruments for develop other free projects. RadekCX |
As for crying, I've done nothing of the sorts other than trying to decifer what you are talking about and trying to reduce your bad mouthing of _my_ many months of work. I think you are misunderstanding my responses as aggressive when all I'm trying to do is figure out what it is you have found. Yes I understand you have produced a commercial driver, but using my driver and it's "buggy" firmware as a reason to purchase yours isn't very friendly.
Alan. |
| from what i understand 1. there is a problem when u turn the motor on i direction the speed is not the same as the opposite direction (it cant reach its max rpm) 2. this is due to a mistake in the datesheet of the lmd 3. this project is commerical but u are posting all the documentation on your web site, i dont know how comes ? so please send alan the page number and line number where is the mistake in the lmd datasheet and what should be corrected, that will be better that trying to decrypt your messages also take it easy alan, your driver is great and everyone knows it i am sure that the langage is causing problem and thats it. max |
#10
| Hi, Somebody who knows Czech language read for me the page about Picstep. I mean the Picstep you built from original schematics. Unfortunately, it is not clear there if the FW you modified from original Picstep is corrected or not. It seems that you did not correct it just modified for full step and 1/16 step. Is this true? Also, you do not mention what jumper setup is needed for each step/microstep function. For your own version of controller/driver it seems that the schematics is the same with picstep, just some opto added. Is this true? Do you sell (the company) already programmed chips and if yes, how and at what price? Thank you. Zoltan |
#11
When I write this version FW I dont know about bug in DS LMD18245. In this FW is identicaly bug as in Alans FW. This FW have only microstepping 1/16 and have not full step.
Comercial driver BiStep http://www.cncnet.info/view.php?naze...nku=2006050002 is partly identical (PIC and LMDs - so FW are compatible) but added 3x optocouplers (DIR, STEP, BRAKE) and DC-DC step-down converter. Linear stabilisator (like 7805) is not suitable for supply 48V. Detail picture Bistep are here: http://www.cncnet.info/gallery.php?m...&galerie_id=11
programmed PIC16F628A-20MHz: 15 euro (I cann send directly) completed Bistep: 80 euro (company mail: zstloukal(at)volny.cz) Next comercial question please on privat contact cncnet.info(at)gmail.com - no on this forum. RadekCX |
#12
| to all simple test: Leave good motor (above 1.5A) freely on wood board and rotate on left and right side with 1/2 microstepping. Listen sound and see resonance - wood board increase sound. One side is different (hard sound) and max rpm and torque on this side rotation is slight. |
