Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PicStep Controllers
PicStep Controllers Discuss PicStep Controllers here!
Old 10-02-2005, 03:22 PM
mk2lehe is on a distinguished road
A picstep clone layout, in eagle (attached)
Finally built and tested my own layout of picstep v4. Maybe someone else might find it useful. The files are in Eagle format. Firmware is found on previous post.
It has a few improvements:
* on board +5V regulation.
* ICSP
* small layout (3x2")
And some 'drawbacks':
* double sided pcb
* smd-components
Feel free asking Q.
Henrik
Old 10-18-2005, 01:51 PM
RTP_Burnsville is on a distinguished road
Looks nice, just a comment - Shouldn't the crystal X1 have a couple small capacitors around 20pf, one to each lead to ground?
Old 10-18-2005, 08:27 PM
Garfield2's Avatar
Garfield2 is on a distinguished road
Nah, he's using a 3 pin resonator that has the caps already encased. Probably wouldn't be a bad idea to allow for them in case someone wants to use a standard can XTal and caps.
-A.
Old 10-18-2005, 09:47 PM
pminmo's Avatar
pminmo is on a distinguished road
MK2,
Nice layout. The only sugggestions I would make is to delete values and cleanup the silkscreen layer. Add a couple of series 1W zeners in input side of the 3 term regulator so a motor voltage up to the max of the lmd part is usable. (i.e. more than 24V)
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 10-19-2005, 02:55 AM
Some protection zeners would be nice. Also one might consider putting in TVS on the motor outputs.
I have caps on X1, but they are smd and therefore not visible on top layer.
Thanks,
Henrik
Old 10-19-2005, 06:52 PM
pminmo's Avatar
I wasn't referring to protection zeners. As the circuit stands now with a 7805 regulator, you can't use a motor voltage greater than 35.7V. It looks to me as though the LMD driver is ok without external diode protection.
Garfield2..Alan..mk2lehe,
Are you ok with me putting this version of the board on my website?
Old 10-20-2005, 03:21 AM
Fine with me!
Henrik
