Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PicStep Controllers
PicStep Controllers Discuss PicStep Controllers here!
Old 05-28-2005, 05:04 PM
randyf1965 is on a distinguished road
Picstep problems continue
I had 2 boards working with my 2 good pic's.. replaced the bad one. Tried to put my breakout board (non OPTO) in place. NOTHING works. I can see the step and direction signal come from the breakout board to the picstep. If I short S1 on the breakout board I get 2 of the led (2 led wired opposite with a resistor to limit current)to dimly light. tried 3 board 4 pic's same issues.
I have also removed the breakout board and wired
parallel pin 2 to picstep pin 7
parallel pin 3 to picstep pin 8
5v to picstep pin 1
gnd to picstep pin 10
gnd parallel pin 22
same thing is seen on output.
thought I was on a roll after the laser printer pc board etching worked so well.... but all has gone rapidly downhill from there,
Picstep problems continue randyf1965 PicStep Controllers 11 07-12-2005 02:24 AM
Open Source Compatable PICstep pminmo Open Source Controller Boards 0 06-11-2005 12:04 PM
PicStep useage questions randyf1965 PicStep Controllers 12 05-25-2005 03:33 PM
Picstep board voltage question dberndt Stepper Motors and Drives 1 01-15-2005 11:34 PM
Accuracy problems i228208 General CAM Discussion 26 05-30-2004 02:31 PM
