control stepper motor driver controller L297 using Pic ????
Results 1 to 6 of 6
Thread: control stepper motor driver controller L297 using Pic ????
    Oct 2005
    Egypt
    Default control stepper motor driver controller L297 using Pic ????
    Dears,
    please help me to control stepper motor driver controller L297 using Pic micro controller .
    i need to generate the step and direction and enable .
    how to do that ?
    watzmann
    Dec 2003
    Lots of Apps on the PicMicro site?
    http://ww1.microchip.com/downloads/e...tes/00822a.pdf
    Oct 2005
    Egypt
    the funny thing had happned ,
    i did connected Enable o 5 volt , and set the direction . now when i only touch the step wire with my finger the stepper motor rotets ...... why ?
    watzmann
    Oct 2005
    Egypt
    thanks for your link , unfortuantly i'm not so good in assembly so i'm trying to find in C or PIC basic .
    what if i wrote a code to generte puleses on thes step pin every 50 micro second , will it work ?
    watzmann
    Jun 2004
    Germany
    Hello watzmann,
    Quote Originally Posted by watzmann View Post
    ... when i only touch the step wire with my finger the stepper motor rotets ...... why ?
    Your body acts a a receiver for any stray AF (50 or 60 Hz power line frequency) and/or RF in the vicinity. Your finger conducts that hodge-podge of frequencies into the CLOCK input of your L297. Whenenver the chip detects a rising edge, it will take that as a clock signal. Not very reliable and potentially dangerous...
    All the best,
    Fred
    Gold Member
    Jan 2005
    Toronto, Canada
    Is there a reason why you want to use the L297? It's a very old design. Better chips are available. The tb6560 requires no microcontroller. But you will need to make sure to follow the proper power sequencing.
