| Pico Systems Motion Control Products Discuss Pico Systems Motion Control Products |
I now have a converter board for the Fanuc "red cap" brushless motors. These have a proprietary scheme for the commutation encoder, and can't be used with industry standard brushless drives. This converter uses the encoder signals to produce standard "Hall" signals for the servo drive. See http://pico-systems.com/oscrc4/catal...products_id=29 for details of this product. Thanks, Jon |
| You will need the pin out of your particular encoder, with some exceptions, the majority of Redcap encoders have 2000/2500 5v differential signals, which can be passed through as-is, the 4 commutation pulses need to be identified. I have not used Jon's interface but I understand he intercepts these pulses and converts to those required for BLDC. There are some encoders to be aware of that are high resolution and these are 1v p-p sine wave signal. If you post the encoder number here and the MS connector size, I have the Fanuc listing for encoder resolution. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Would you be able to figure it from the motor model number? I haven't bought the motor yet and don't want to until I know it will work.
| If you PM me an email add, I can send you what I have, unfortunately Fanuc use a whole raft of different part numbers for some reason? Al.
| There are also absolute encoders, and incremental encoders that produce the industry-standard Hall signals directly. If you have a model number for the motor, I have a table (provided by "Al the man" who knows a LOT about these motors) which tells how to figure out the encoder type from the motor part #. My converter handles 1500, 2000, 2500 and 10,000 pulse/rev encoders. I can give you a pinout for the 17-pin connector. Jon |
| Problem- Fanuc 0iMC - Scales vs Encoders. Accuracy. | Leha_Blin | Fanuc | 7 | 10-20-2008 01:14 PM |
| where can I buy encoders w/Hall for brushless motors for reasonalbe? | springlakecnc | General CNC (Mill and Lathe) Control Software (NC) | 3 | 09-17-2007 05:05 PM |
| Need info on Fanuc brushless motor | KTP | Servo Motors and Drives | 14 | 05-12-2006 01:19 PM |
| Brushless DC servos VS. Brushless R/C motors | sp1nm0nkey | Servo Motors and Drives | 1 | 03-07-2006 10:37 AM |
| Brushed vs Brushless encoders | bdillard | General Electronics Discussion | 8 | 01-22-2006 02:19 PM |
