Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PIC Programing / Design
PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips.
Old 02-21-2005, 10:16 AM
elizeu is on a distinguished road
Question CNC Controller PIC 16F877 - From Brasil
I need help ..!
Please i like about cnc controller with pic 16F877 and parallel port, i need source code.
Old 02-21-2005, 02:09 PM
TinkerDJ is on a distinguished road
You and me both.
There are several websites out there, with the same idea.
http://cstep.luberth.com/
Goto to the bottom of the first page listed and there is a few other pic877 controllers listed.
I'm working on one but i want have code for it any time soon.
Have a good one.
Dave
Old 02-22-2005, 10:16 AM
Swede's Avatar
Swede is on a distinguished road
Good luck. PIC's are amazingly capable but very low-level devices. I spent two years coding a PIC16F876 to control a model turbojet engine. I don't know your background, but I found that a copy of PICBASIC Pro to be incredibly helpful, and the code, unlike a BASIC stamp, is actually compiled, not interpreted, so the speed doesn't suffer too badly.
Old 08-15-2005, 08:37 PM
samsagaz is on a distinguished road
is possible to control perfectly an CNC machine using an pic?
Old 12-04-2005, 03:10 PM
aquasapien's Avatar
aquasapien is on a distinguished road
I have built a cnc system using 16F84 and uln 2003's. Problem is using Kcam I plot a circle and the cnc output is a diamond. I think I am reading the step variable wrong. When I output the data to hyperterm it seems like I am reading it right but output is like I said....square not circle. Any suggestions?
Old 12-04-2005, 04:07 PM
CLaNZeR's Avatar
CLaNZeR is on a distinguished road
Find attached our Firmware for the Processor Board using the 18F4550, it nearly the same as the 16F877 but has the USB as well as serial input, please follow processor board link at http://www.cncdudez.com
All the pin outs and link information is on the site, so you can design your own board.
Along with the protocol to drive your motors via usb or serial port.
Regards
Sean.
Originally Posted by elizeu
I need help ..!
http://www.cncdudez.co.uk
Old 12-04-2005, 04:14 PM
CLaNZeR's Avatar
You need to convert the objects in your DXF files from Arcs to Spline vectors. This will get rid of the arcs and leave you with Beziers.
Then export them as DXF's and import in Kcam and you will get your curves and not straight lines.
Regards
Sean.
Old 01-14-2006, 06:04 AM
Moderator
dewayne is on a distinguished road
18f4550
The pinout information seems to be missing
Cheers
Regards
Sean.
DeWayne
Old 01-14-2006, 06:44 AM
CLaNZeR's Avatar
The pinouts are on the Firmware link at the bottom and shows what each port on the 18F4550 does.
Regards
Sean.
Old 10-06-2006, 06:22 AM
fcoupez is on a distinguished road
I've try both CNCDunez and InterpCNC board with GALAAD.
InterpCNC board is very useful and perfect for hobbys't use.
The bigest advantage of this board is that you can use Ninos or GALAAD.
Ninos is very cheap and GALAAD is not so cheap but very powerful.
This board is the cheapest way to use GALAAD.
Information on InterpCNC are available here :
http://hdarret.free.fr/cnc2/projet_interpolateur.htm
It's in french but you can contact the author in English. Ther's no problem for him.
Regards
Sean.
  #11   Ban this user!
Old 10-22-2006, 02:06 PM
davesaudio is on a distinguished road
Thats a normal step and direction input controller?
maybe...
  #12   Ban this user!
Old 10-23-2006, 05:01 PM
Controller output
Yes, outputs are Step/Dir for 4 axes. I'm using only 3.
Regards,
francois
CNC controller osdhillon General CNC (Mill and Lathe) Control Software (NC) 8 11-06-2007 11:13 PM
Open Source CNC Controller Specification gregmary DIY-CNC Router Table Machines 28 12-04-2005 10:58 PM
3D or 2D MAXI Style Hobby CNC PWM Controller! icm Product Announcements & Manufacturer News 1 01-05-2005 09:36 AM
3D/2D PIC PWM Step/Dir CNC Controller icm Product Announcements & Manufacturer News 7 09-19-2004 10:05 AM
