| PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips. |
Hi can someone show me how to change the code for the Timeout from 5mins-45sec to 10 sec PIC16F628A LMD18245 Also is it possiblle to power down my steppers when idle in Mach 3 this is a feature in Kcam which I found very usefull All assistance much appreciated CHEERS Nick This is the ASM file from Alan Garfield title "PICStep V2.0" LIST R=DEC #INCLUDE P16F628A.INC #define TIMEOUT_ENABLED ; Registers UDATA 0x020 step RES 1 portA_shadow RES 1 mode RES 1 lookup RES 1 temp RES 1 timeout_reg RES 1 timeout RES 2 _w RES 1 _status RES 1 _fsr RES 1 _pclath RES 1 __CONFIG _CP_OFF & _WDT_ON & _HS_OSC & _PWRTE_ON & _LVP_OFF & _BOREN_ON & _MCLRE_OFF org 0 goto Mainline ; Main line vector org 4 goto Interupt ; Interupt vector CODE Interupt ; Save Current Context movwf _w movf STATUS, w bcf STATUS, RP1 bcf STATUS, RP0 movwf _status movf FSR, w movwf _fsr movf PCLATH, w movwf _pclath clrf PCLATH ; Interrupt service routine btfsc INTCON, INTF call INTB0 ; Call INTBO interrupt handler #ifdef TIMEOUT_ENABLED btfsc PIR1, TMR2IF call TIMEOUT ; Call TIMEOUT interrupt handler #endif ; Reset Current Context movf _pclath, w movwf PCLATH movf _fsr, w movwf FSR movf _status, w movwf STATUS swapf _w, f swapf _w, w retfie INTB0 ; Handle interupt on RB0 #ifdef TIMEOUT_ENABLED clrf timeout ; Reset timeout timer and register clrf timeout + 1 clrf timeout_reg #endif ; Advance the index position movlw HIGH MODE_TABLE movwf PCLATH movf mode, w ; Load the current mode call MODE_TABLE ; Get the advance value for this mode movwf lookup ; Store it for later btfss PORTB, 1 ; Check on the direction pin (RB1) goto $ + 4 ; Jump over step addition addwf step, w ; Add the current mode to the current position value movwf step ; Update step goto $ + 3 ; Jump over step subtraction subwf step, w ; Subtract the current mode from the current position value movwf step ; Update step ; Bounds check the table movlw 0x040 ; Check if step has overflowed the edge of the table subwf step, w btfsc STATUS, Z clrf step movf lookup, w ; Check if step has underflowed the edge of the table sublw 0x040 subwf step, w btfsc STATUS, C subwf step, f ; Process DAC A movlw HIGH STEP_TABLE_A movwf PCLATH movf step, w ; Reload step into w call STEP_TABLE_A ; Get the result from the table movwf lookup ; Store the fetched results for later btfss PORTB, 1 ; Check on the direction pin (RB1) rlf lookup, w ; Rotate to the alternate direction bit to fix a bug in LMD xorwf PORTB, w ; Prepare the direction bit for DAC A andlw B'10000000' ; Mask out the direction bit xorwf PORTB, f ; Output the direction bit movf lookup, w ; Reload the fetched table results andlw B'00001111' ; Mask out the upper nibble movwf PORTA ; Output the DAC results for A ; Process DAC B movlw HIGH STEP_TABLE_B movwf PCLATH movf step, w ; Reload step into w call STEP_TABLE_B ; Get the result from the table movwf lookup ; Store the fetched results for later btfss PORTB, 1 ; Check on the direction pin (RB1) rlf lookup, w ; Rotate to the alternate direction bit to fix a bug in LMD xorwf PORTB, w ; Prepare the direction bit for DAC B andlw B'01000000' ; Mask out the direction bit xorwf PORTB, f ; Output the direction bit rlf lookup, f ; Rotate lookup left in place rlf lookup, w ; Rotate again but into WREG xorwf PORTB, w andlw B'00111100' ; Mask out the not needed bits xorwf PORTB, f ; Output the DAC results for B bcf INTCON, INTF ; Clear RB0 Interrupt flag return #ifdef TIMEOUT_ENABLED TIMEOUT ; Handle motor timeout TMR2 interrupt and return ASAP bsf timeout_reg, 7 ; Set the timeout bit so the count can increment bcf PIR1, TMR2IF ; Clear TMR2 Interrupt flag return #endif Mainline ; Initialize Variables clrf step clrf mode clrf lookup #ifdef TIMEOUT_ENABLED clrf timeout clrf timeout + 1 clrf timeout_reg #endif ; Setup I/O ports / Timers clrf PORTA ;Initialize PORTA clrf PORTB ;Initialize PORTB movlw (1 << CM0) | (1 << CM1) | (1 << CM2) ;Turn comparators off and movwf CMCON ;enable pins for I/O bcf STATUS, RP1 bsf STATUS, RP0 ;Select Bank1 movlw B'11110000' ;Set RA<0:3> as outputs movwf TRISA ^ 0x080 movlw B'00000011' ;Set RB<2:7> as outputs movwf TRISB ^ 0x080 movlw (1 << INTEDG) ;Setup Interupt Edge movwf OPTION_REG ^ 0x080 #ifdef TIMEOUT_ENABLED movlw (1 << TMR2IE) ; Enable TMR2 Interupt movwf PIE1 ^ 0x080 bcf STATUS, RP0 ;Select Bank0 movlw B'01111111' ; Turn on TMR2 with 1/16 pre and post scaler movwf T2CON ^ 0x080 #endif movlw (1 << GIE) | (1 << INTE) | (1 << PEIE) ; Enable global interupts, perph and RB0 Interupts movwf INTCON ^ 0x080 Loop ; Clear the watchdog timer (maximum loop for entire code is ~0.18ms watchdog is 18ms plenty of time!) clrwdt ; Monitor the mode switches movf PORTA, w movwf temp rrf temp, f rrf temp, f rrf temp, f rrf temp, w andlw B'00000011' movwf mode #ifdef TIMEOUT_ENABLED ; Motor timeout counter btfss timeout_reg, 7 ; Check to see if a timeout interrupt has occured goto Loop ; Timeout interrupt occured updated counter bcf timeout_reg, 7 ; Reset the Interrupt flag incfsz timeout, w ; Increment the 16 bit timeout value decf timeout + 1, f incf timeout + 1, f movwf timeout iorwf timeout + 1, w movwf timeout ; Test if the timeout value has overflowed btfss STATUS, Z goto Loop movwf timeout + 1 btfss STATUS, Z goto Loop incf timeout_reg, f ; Increase the timeout reg value btfss timeout_reg, 2 ; Check we've been around the 4 times of the 16 bit counter (~5 minutes 45 seconds @ 20MHz) goto Loop ; Timeout! clrf PORTA ; Reset PORTA and PORTB to turn off the motors clrf PORTB ; The next INTB0 will awaken them again #endif goto Loop org 0x100 ; 1/16 Step DAC A Table STEP_TABLE_A addwf PCL, 1 ;Deg DAC A retlw B'01000000' ;0 0.00 0 --- retlw B'00000001' ;5 0.10 1 retlw B'00000010' ;11 0.20 2 retlw B'00000100' ;16 0.29 4 retlw B'00000101' ;22 0.38 5 retlw B'00000111' ;28 0.47 7 retlw B'00001000' ;33 0.56 8 retlw B'00001001' ;39 0.63 9 retlw B'00001010' ;45 0.71 10 retlw B'00001011' ;50 0.77 11 retlw B'00001100' ;56 0.83 12 retlw B'00001101' ;61 0.88 13 retlw B'00001101' ;67 0.92 13 retlw B'00001110' ;73 0.96 14 retlw B'00001110' ;78 0.98 14 retlw B'00001110' ;84 1.00 14 retlw B'00001111' ;90 1.00 15 --- retlw B'00001110' ;95 1.00 14 retlw B'00001110' ;101 0.98 14 retlw B'00001110' ;106 0.96 14 retlw B'00001101' ;112 0.92 13 retlw B'00001101' ;118 0.88 13 retlw B'00001100' ;123 0.83 12 retlw B'00001011' ;129 0.77 11 retlw B'00001010' ;135 0.71 10 retlw B'00001001' ;140 0.63 9 retlw B'00001000' ;146 0.56 8 retlw B'00000111' ;151 0.47 7 retlw B'00000101' ;157 0.38 5 retlw B'00000100' ;163 0.29 4 retlw B'00000010' ;168 0.20 2 retlw B'00000001' ;174 0.10 1 retlw B'10000000' ;180 0.00 0 --- retlw B'11000001' ;185 -0.10 -1 retlw B'11000010' ;191 -0.20 -2 retlw B'11000100' ;196 -0.29 -4 retlw B'11000101' ;202 -0.38 -5 retlw B'11000111' ;208 -0.47 -7 retlw B'11001000' ;213 -0.56 -8 retlw B'11001001' ;219 -0.63 -9 retlw B'11001010' ;225 -0.71 -10 retlw B'11001011' ;230 -0.77 -11 retlw B'11001100' ;236 -0.83 -12 retlw B'11001101' ;241 -0.88 -13 retlw B'11001101' ;247 -0.92 -13 retlw B'11001110' ;253 -0.96 -14 retlw B'11001110' ;258 -0.98 -14 retlw B'11001110' ;264 -1.00 -14 retlw B'11001111' ;270 -1.00 -15 retlw B'11001110' ;275 -1.00 -14 --- retlw B'11001110' ;281 -0.98 -14 retlw B'11001110' ;286 -0.96 -14 retlw B'11001101' ;292 -0.92 -13 retlw B'11001101' ;298 -0.88 -13 retlw B'11001100' ;303 -0.83 -12 retlw B'11001011' ;309 -0.77 -11 retlw B'11001010' ;315 -0.71 -10 retlw B'11001001' ;320 -0.63 -9 retlw B'11001000' ;326 -0.56 -8 retlw B'11000111' ;331 -0.47 -7 retlw B'11000101' ;337 -0.38 -5 retlw B'11000100' ;343 -0.29 -4 retlw B'11000010' ;348 -0.20 -2 retlw B'11000001' ;354 -0.10 -1 ; 1/16 Step DAC B Table STEP_TABLE_B addwf PCL, 1 ;Deg DAC B retlw B'01101111' ;0 -1.00 -15 --- retlw B'01101110' ;5 -1.00 -14 retlw B'01101110' ;11 -0.98 -14 retlw B'01101110' ;16 -0.96 -14 retlw B'01101101' ;22 -0.92 -13 retlw B'01101101' ;28 -0.88 -13 retlw B'01101100' ;33 -0.83 -12 retlw B'01101011' ;39 -0.77 -11 retlw B'01101010' ;45 -0.71 -10 retlw B'01101001' ;50 -0.63 -9 retlw B'01101000' ;56 -0.56 -8 retlw B'01100111' ;61 -0.47 -7 retlw B'01100101' ;67 -0.38 -5 retlw B'01100100' ;73 -0.29 -4 retlw B'01100010' ;78 -0.20 -2 retlw B'01100001' ;84 -0.10 -1 retlw B'00100000' ;90 0.00 0 --- retlw B'00000001' ;95 0.10 1 retlw B'00000010' ;101 0.20 2 retlw B'00000100' ;106 0.29 4 retlw B'00000101' ;112 0.38 5 retlw B'00000111' ;118 0.47 7 retlw B'00001000' ;123 0.56 8 retlw B'00001001' ;129 0.63 9 retlw B'00001010' ;135 0.71 10 retlw B'00001011' ;140 0.77 11 retlw B'00001100' ;146 0.83 12 retlw B'00001101' ;151 0.88 13 retlw B'00001101' ;157 0.92 13 retlw B'00001110' ;163 0.96 14 retlw B'00001110' ;168 0.98 14 retlw B'00001110' ;174 1.00 14 retlw B'00001111' ;180 1.00 15 --- retlw B'00001110' ;185 1.00 14 retlw B'00001110' ;191 0.98 14 retlw B'00001110' ;196 0.96 14 retlw B'00001101' ;202 0.92 13 retlw B'00001101' ;208 0.88 13 retlw B'00001100' ;213 0.83 12 retlw B'00001011' ;219 0.77 11 retlw B'00001010' ;225 0.71 10 retlw B'00001001' ;230 0.63 9 retlw B'00001000' ;236 0.56 8 retlw B'00000111' ;241 0.47 7 retlw B'00000101' ;247 0.38 5 retlw B'00000100' ;253 0.29 4 retlw B'00000010' ;258 0.20 2 retlw B'00000001' ;264 0.10 1 retlw B'01000000' ;270 0.00 0 --- retlw B'01100001' ;275 -0.10 -1 retlw B'01100010' ;281 -0.20 -2 retlw B'01100100' ;286 -0.29 -4 retlw B'01100101' ;292 -0.38 -5 retlw B'01100111' ;298 -0.47 -7 retlw B'01101000' ;303 -0.56 -8 retlw B'01101001' ;309 -0.63 -9 retlw B'01101010' ;315 -0.71 -10 retlw B'01101011' ;320 -0.77 -11 retlw B'01101100' ;326 -0.83 -12 retlw B'01101101' ;331 -0.88 -13 retlw B'01101101' ;337 -0.92 -13 retlw B'01101110' ;343 -0.96 -14 retlw B'01101110' ;348 -0.98 -14 retlw B'01101110' ;354 -1.00 -14 MODE_TABLE addwf PCL, 1 retlw 0x001 ; 1/16 retlw 0x002 ; 1/8 retlw 0x004 ; 1/4 retlw 0x008 ; 1/2 end |
| It looks like the amount iterations of the Timer_reg maybe will change it, Timer 2 is already set for 16 pre/post scaling. Maybe running it through the MLAB simulator will show where you can increase it? Al.
| Need Help!- My Milling OKK with fanuc 6M can't recognize G-code & M-code | nessei | Fanuc | 4 | 03-29-2011 08:39 AM |
| Newbie- Takeout Unused G Code commands in Mastercams Generated G Code | shneek | Mastercam | 8 | 12-15-2010 02:32 PM |
| Need Help!- G-Code viewing source code | Hussam | Visual Basic | 3 | 03-15-2009 12:15 PM |
| G-code for beginners - want to learn G-code | FPV_GTp | G-Code Programing | 7 | 11-17-2008 11:25 PM |
| looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft | troyswood | Ability Systems - LPT Indexer and G-Code | 2 | 12-24-2006 09:21 PM |
