Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PIC Programing / Design
PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips.
Old 03-19-2009, 04:11 AM
rainman is on a distinguished road
New to microcontroller
Hi all,
I'm new to microcontroller, I wish to try out running a miniature servo motor with it.
I will be using PICkit and MPLAB, what the the differences between the 2?
I'm trying to understand the steps in making it work.
Thanks.
Cheers!
Old 03-19-2009, 10:08 AM
neilw20's Avatar
neilw20 is on a distinguished road
Yuo will probably crawl before you walk.
Each PIC has it's own peculiarities, as do most CPUs.
MPLAB is the development environment.
PICkit (2) is one of the hardware environments for development/programming.
Other development tools are:
MPLAB SIM, a simulator
MPLAB ICE 2000 and ICE 4000, sophisticated hardware development environments that allow single stepping, breakpoints amongst other features.
MPLAB ICD 2 is development debugger/programmer with limited features, and cost.
Start with a few of the simple examples and make a LED blink, and read a switch, then as you learn make your environment more complex.
If you start off complex, nothing will work first off (unless you are a nerd)
KISS. Keep It Simple, Stupid is a good approach.
Each chip type has features and hurdles during development.
You get one working nicely. Change to a different chip, then have to learn new features.
Welcome to pre-school.
Then there is the programming languages to choose from, according to how deep your pocket is.
You will probably start with assembler.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
need help to connect microcontroller to stepper driver xinzc28 General Electronics Discussion 0 11-07-2008 02:59 AM
serial port+microcontroller visky General Electronics Discussion 1 10-28-2007 08:48 PM
Microcontroller project in exchange for CNC godies DennisCNC General Electronics Discussion 7 07-11-2007 03:23 PM
MicroController/DSP based Motion interface Haz General Electronics Discussion 3 03-22-2007 03:54 PM
Discrete transistors and AVR microcontroller DukerX Open Source Controller Boards 26 03-04-2006 07:30 AM
