Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PIC Programing / Design
PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips.
  #97   Ban this user!
Old 02-05-2012, 07:06 AM
aadityadengle is on a distinguished road
tried to connect with Magnetic Encoder but no use
DATA == Cha A
Clk == /A
  #98   Ban this user!
Old 02-06-2012, 06:14 AM
BillTodd is on a distinguished road
Originally Posted by aadityadengle View Post
Yes!!!! Phase A & B with TTL I am using Magnetic Encoder ME6012 { Data sheet available @ ( http://www.google.co.in/url?sa=t&rct..._DNsH1LkQBYTZQ ) }
Now can I use it with your circuit. I am new to the electronics
No Sorry
My PIC code works only with the 'chinese' LCD callipers (these output a binary code).
Your scale needs a 'quadrature' counter - you may be able to find some other software to work with the scale (I believe the linux based EMC2 can do this)
Bill
Bill
  #99   Ban this user!
Old 02-06-2012, 06:28 AM
tried the circuit with verniers too
but no data
  #100   Ban this user!
Old 02-06-2012, 01:20 PM
but no data
like that's going to get you an answer !
Bill
  #101   Ban this user!
Old 02-07-2012, 05:46 AM
komatias is on a distinguished road
Hi Bill,
first off, you might want to think about adding a donate button to you signature!4 years later and there are people still interested in your work.
You got me to join another forum just to ask you a question. Pretty simple one it should be:
Do I need visual studio to get your program to install? I keep getting:
unable to register the dll ocx regsvr32 failed with exit code 0x4
on both my computers.
looking forward to your response.
Regards
George
  #102   Ban this user!
Old 02-07-2012, 12:03 PM
Hi George,
The program is written in VB5, so you should not need VS at all.
It was designed for Windows 95. I have not tried it on Vista or Win7, so that may be the problem (can you install on a VM or as XP?).
the install script ireads:
Source: "d:\My Documents\VB5 projects\Logger\Vernier.exe"; DestDir: "{app}"; Flags: ignoreversion
Source: "e:\VB\System Files\MSVBVM50.dll"; DestDir: "{sys}"; Flags: onlyifdoesntexist uninsneveruninstall
Source: "e:\VB\System Files\OleAut32.dll"; DestDir: "{sys}"; Flags: onlyifdoesntexist sharedfile regserver
Source: "e:\VB\System Files\OlePro32.dll"; DestDir: "{sys}"; Flags: sharedfile regserver
Source: "e:\VB\System Files\AsycFilt.dll"; DestDir: "{sys}"; Flags: sharedfile
;Source: "e:\VB\System Files\Ctl3d32.dll"; DestDir: "{sys}"; Flags: sharedfile
Source: "e:\VB\System Files\StdOle2.tlb"; DestDir: "{sys}"; Flags: sharedfile
Source: "e:\VB\System Files\MSCOMM32.OCX"; DestDir: "{sys}"; Flags: sharedfile regserver
Source: "e:\VB\System Files\SCRRUN.DLL"; DestDir: "{sys}"; Flags: sharedfile
Source: "e:\VB\System Files\comcat v471\Comcat.dll"; DestDir: "{sys}"; Flags: sharedfile regserver
so there are only 4 files that require regserver.
4 years? I started this in 2005! that's the problem!
There are new scales out now that do not work with the PIC code (so be warned) At some point (way in the future), when I get one of the newer 21 bit devices I'll add it to the PIC.
Meanwhile, I get people like aadityadengle waving bs flags at me, because they cant get it working!
Is does work with the right scales:
Bill
  #103   Ban this user!
Old 02-07-2012, 12:54 PM
Question
PIC based DRO - YouTube
IT DID NOT WORKED FOR ME. BUT STILL WORKING ON IT.
  #104   Ban this user!
Old 02-07-2012, 01:51 PM
My guess is that you have igaging type scales (or yet another chinese type that I have not seen)
The Igaging scales are quite different and in some ways better, but they will require a different PIC code:
21 Bit Protocol Scales | shumatech.com
(BTW A big thankyou to Shumatech for making their research public
Bill
  #105   Ban this user!
Old 02-08-2012, 02:33 AM
Hi Bill,
thanks for the answer. I am trying to install it in windows XP. It is apparently trying to register inpout32.dll into the Regserver. will investigate and write back.
  #106   Ban this user!
Old 02-08-2012, 06:27 AM
Originally Posted by komatias View Post
Hi Bill,
Ah! I think you have the wrong version. The inpout.dll is only required on my POS board. (not sure why it wont install though)
Give me a day or two and I'll compile a different version
Bill
Bill
  #107   Ban this user!
Old 02-08-2012, 01:22 PM
OK this is a versio without the inpout.dll so should install OK (fingers crossed because I have not got a virgin machine to try it on)
Bill
Bill
  #108   Ban this user!
Old 02-09-2012, 03:42 PM
Sorted! Thanks Bill
Is water based CNCadmin Safety Zone 44 10-15-2010 02:27 PM
Need help with CNC UK based ciscoe Europe Club House 1 07-21-2008 06:03 AM
Convert to PC based Arcticfox46 CNC Wood Router Project Log 4 08-10-2007 08:05 AM
Used CMM based DIY router? biomed_eng DIY-CNC Router Table Machines 1 10-16-2006 08:52 PM
dos based cnc software flyingmike Computers and Networking 14 11-25-2005 01:29 PM
