Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PIC Programing / Design
PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips.
Old 02-12-2008, 12:12 AM
vulcom1 is on a distinguished road
Velleman 8048 board
I am trying to learn a bit on how to program a chip. I bought this board to do some testing and will get something better later. After spending quite a while trying to get something to run (leds blinking) which I finally got running I found another problem. With a 628 or 627 in the holder it is okay but when I insert a PIC16F648A I get a dim pulsing on the led9 led. With the light on it says to not remove or insert a device. Does anybody else have or seen this problem? I have quite a few 648's and do not want to smoke them. Any response will be appreciatted for this beginner.
Thanks, John
Old 02-13-2008, 12:38 PM
I don't have a schematic of the board but if somebody has one it would be appreciatted. Another question is if anybody has a board could they check to see if there is continuity between pins 27 and 28 on the 28 pin socket. I know they are all interconnected but not sure of the traces.
Thanks for any help as it is appreciated.
John
Old 04-20-2008, 04:46 PM
micron2121 is on a distinguished road
Hope this helps
Pic programming? velleman k8048 j m PIC Programing / Design 62 04-12-2009 02:56 AM
Velleman HPS40 Scope carlquib General Electronics Discussion 1 10-10-2007 09:50 AM
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 08:55 PM
Can I hook up a 3-axis board to a 1-axis board ? Redline Xylotex 7 02-09-2007 10:45 PM
Bad Board? fool Xylotex 1 02-06-2006 02:30 PM
