The channels with the over score or NOT are the complement or inverse of the channel which is not overscored, this is a differential encoder and is made this way to implement noise cancellation, it uses a differential driver IC.
If you only want a A & B channel you can ignore the /A & /B.
The I & /I are the index or marker , one per rev pulse
LinkBack URL
About LinkBacks
