Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PIC Programing / Design
PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips.
Old 07-13-2007, 07:32 AM
randyf1965 is on a distinguished road
Help with Pic 16F628A
I built a JDMProg programmer (serial port on pc running XP sp2) a year or so ago and use WinPic. I recently erased and reprogrammed 3 pic's for my PicStep stepper drivers. Now out of 8 pics 7 of them come back when I try to program them saying that progrmming failed at 0000h.
HOW did I kill 7 pic's? If I erase them it says it was successful, a read fails stating pic may be blank.
Old 07-14-2007, 10:37 PM
Problem was in my JDM programmer. I found a bad solder joint on a transistor, resoldered and all but 1 of the pic worked properly
Old 12-31-2007, 02:52 PM
FunnyNYPD's Avatar
FunnyNYPD is on a distinguished road
Smile
you can also try to get the low cost PICkit2. Or build one for yourself quick.
Here is more info for the PICKit2 DIY fans:
http://www.edaboard.com/ftopic273287.html
Old 02-06-2008, 01:33 PM
FunnyNYPD's Avatar
you can also check one of my tuturial about how to program DIP package PICs with breadboard:
http://www.auelectronics.selfip.com/Q8.htm
