| PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips. |
Hi everybody. I'm new to that kind of stuff but I plan to make my first router. I'm in the development of my own stepper driver board. I use a PIC16F685. I want to implement FULL step, HALF step and MicroStepping mode in my driver board. I'll use discrete N channels mosfets with FET drivers to raise Vsup up to 60-80 volts. I'm inspired by the geckodrives. 1- Now, as I'm totally new to cnc, what would be a great target as maximum step frequency ?? I've read the Gocko's manual and they stipulate a max step frequency of 200kHz. Even with a crystal at 20MHz, I can't get more than 75kHz of step speed with my pic's program. For a 1/8th microstep mode it gives me a max speed of 2812RPM which is 2.34 inch/sec with a 0.050" pitch ballscrew. 2- Is that fast enough ?? Thanks for the replies and all suggestions are welcomed. niclatrique |
| If you are going to use a parallel port control, you won't get over about 45kHz step frequecy. As far as if thats fast enough, you won't have a whole lot of torque at that speed. Also you'll need to impliment some form of damping to get through the midband resonance issues. 0.050 pitch ballscrew? do you mean leadscrew? I haven't seen a ballscrew with that small of a lead. Aaron |
Thanks for the reply on this. You make me confident on the work I already did. I need to read about the midband reasonnance now... About the ballscrew, by ballscrew, I mean an endless screw with rounded thread which carry a nut with bearings inside its body. Anyway, thanks a lot for the advice on the step frequency. Best regards, nic |
| 0.050 pitch is 20 turns to move 1 inch - I didn't think they made ballscrews that fine. As far as stepping at 200KHz, you won't be microstepping at that speed - you'll need to switch to full steps long before, so you only need to be able to support 25000 full steps per second. A 200 step.rev motor would turn at 7500RPM at 25000step/sec - without very special motors you'll never get to this speed with any torque left. Aaron |
