| PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips. |
I made a mechanical modification to the Linistepper by installing 3-position female headers (digikey S7036-ND) where the TIP 122's go. I then took the heatsink from a Masscool CPU Cooling Fan (tigerdirect item #S457-1111) and drilled and tapped four holes into it at 1/2" centers and 9/16" up from the edge. I also drilled and tapped two holes on the fin surface of the heatsink (lies coplanar with the circuit board). These holes line up with the two outer TIP holes and are 19/32" from the heatsink edge (same edge that the TIP holes are referenced from). They also are drilled and tapped to a depth to penetrate two fins. The stand off's were cut from 1/4" aluminum tubing to a finish length of 9/16". The screws used are all #4-40. The ones holding the TIP's down are 3/8" long and the two for the stand off's are 1" long. Following the best mechanical practise I used a lock washer and flat washer under the head of each screw. Belleville washers are recommended for the TIP's but they seem too expensive at $.50 each so I used split ring. I rubbed the backs of the TIP's on a sharp file to get the best contact surface possible. I also filed the mating heatsink surface and then polished it with some steel wool. In place of mica and paste I used Berquist silicone heat pads (digikey BER220-ND). With 1A steppers at 24V I'm unable to detect by touch any heat rise in the TIP's. I feel that this is a better solution than the bracket that the kit suggests because it eliminates a heat transfer junction and it allows for very easy replacement of the TIP's. Also if you have to drill and prepare a piece of angle for a bracket why not just do the same right on a fan cooled heatsink? The small cost of the additional parts seems insignificant compared to the utility of the final product. Chris |
