Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PIC Programing / Design
PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips.
Old 03-25-2006, 04:08 PM
islambadr is on a distinguished road
need help
can any one tell me how to use pic microcontroller to control servo motors by step/dir signals
Old 03-25-2006, 08:29 PM
One of Many is on a distinguished road
Servo motors are normally driven by a servo amp which takes an analog signal(typically between +/- 10v with tach(velocity) and encoder(position) feedback for closed loop control) . Step and direction are digital outputs to a stepper motor controller(Open loop, but some systems are going toward closed loop with encoder feedback). There may be some brushless servo drivers that will take step and direction, but they are quite expensive.
What kind of project are you planning?
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 03-26-2006, 01:56 PM
H500 is on a distinguished road
Quite simple, set up a PID algorithm on the PIC. The STEP input will increment or decrement the target position depending on the DIR input.
Old 03-26-2006, 02:04 PM
DC
I'm planning to build a cnc machine .I will use DC servo motors and want to use pic microcontroller to drive these motors.
If you know how to deal with the analog signals please tell me
and
What is the software should i use?
