The MICRFxxx radio chips from Micrel looks easy to use and is available from digikey. I believe they "replace" the wires that normally connect the Tx to the Rx pins between two uarts. The most obvious approach is to encode the information in several bytes and transmit them as RS232 using the PIC's uart.
LinkBack URL
About LinkBacks
