Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PIC Programing / Design
PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips.
  #25   Ban this user!
Old 06-30-2005, 05:56 AM
smarbaga is on a distinguished road
a six volt power supply is to high, the max is 5.5v.
use a 7805 regulator and make sure you have 5.1 volts
  #26   Ban this user!
Old 06-30-2005, 06:56 AM
posix is on a distinguished road
OK Working now. When taking measurements I found an odd reading. 0.06v one side of a resistor (input to RA3) and 1.2v on the other side. Followed the trace and I found a teeny weeny short, hardly noticable by naked eye (is it possible that solder splashes?) between RS3 pin and OSC1 trace. Tip of the scalpel was enough to get rid of it and now it's all working 100%.
So I guess if your OSC1 is shorted to something your 16F628 doesn't work no matter whether you use the internal or external oscilator. Which shouldn't really be the case as OSC1 pin is used for I/O if you program the device with IntRC I/O, right?
  #27   Ban this user!
Old 06-30-2005, 07:26 PM
abasir's Avatar
abasir is on a distinguished road
On homemade PCB, shorts and breaks are normal occurence... I usually check the board with multimeter for trace continuity/break prior to soldering... Now, I'm planning to build a current tracer to pinpoint exact location of short/break for cases where the problem is hardly visible
Your RA3 is input (may be for STEP) and you configured OSC1 for IO (possible either high/low). Thus, your RA3 is stuck to a given level (either high/low) eventhough the PIC may be operating... no change in input, the PIC just stay put
Stupid questions make me smarter...
See how smart I've become at www.9w2bsr.com ;-P
  #28   Ban this user!
Old 07-01-2005, 02:27 AM
Now that you put it that way it's perfectly logical.
PIC Open source Servo Driver Schematics development? Rossz Open Source Controller Boards 90 10-26-2011 03:37 PM
CNC Controller PIC 16F877 - From Brasil elizeu PIC Programing / Design 12 05-04-2009 07:49 AM
Need PIC programmed randyf1965 CNC Wood Router Project Log 0 03-26-2005 05:56 PM
pic chip SERIAL to step/dir and controll berin Open Source Controller Boards 13 02-18-2005 05:23 PM
Posting pic from the galley CNCadmin CNCzone Club House 1 07-10-2003 05:30 PM
