Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > PIC Programing / Design
PIC Programing / Design Discuss programing of PIC chips here and design of electronics using PIC chips.
Old 03-29-2010, 06:35 PM
Richotech is on a distinguished road
DC Servo quadrature control using microcontroller
Hello,
I have many quality DC servo motors with attached optical encoders and was keen on using a microcontroller to control a 3-axis machine. Maybe using Mach3.
Is this there any chips that you could recommend to use.
Cheers,
Brett.
Old 03-30-2010, 02:08 AM
H.O H.O is offline
H.O is on a distinguished road
Personally I've played around with the PIC18F2431/4431. It's quite cool with hardware quadrature decoder/counter and its power control PWM module. If you need more "power" there are similar PICs available in the higher end series as well. I'm sure other manufacturers will have similar chips.
Old 04-11-2010, 09:03 AM
rlwoodjr is on a distinguished road
I am attempting this using the arduion board. I pan to use one board per axis.
Old 08-02-2010, 06:16 PM
Oceano is on a distinguished road
Hello everyone. I am new to the forum, this is my first message here. Please excuse my way of expressing myself.
Just saying that there are, for some time, absolute encoders on a chip. They have different resolutions depending on the model (8 .. 13 bits). It operates through a magnet to find the angle.
With a single PIC can control all absolute encoders need. The simplest example is the AM256 (8 bits) of the company RLS.
Best Regards.
Old 08-02-2010, 10:54 PM
Iron-Man's Avatar
Iron-Man is on a distinguished road
dsPIC Servo
Check out all the work here.
http://www.cnczone.com/forums/showthread.php?t=40940
Iron-Man
Fadal external servo control or Haas external servo control carbidecraters Fadal 12 09-16-2011 11:25 PM
New to microcontroller rainman PIC Programing / Design 1 03-19-2009 10:08 AM
Need Help!- quadrature division propclock General Electronics Discussion 2 12-31-2008 06:21 AM
serial port+microcontroller visky General Electronics Discussion 1 10-28-2007 08:48 PM
Discrete transistors and AVR microcontroller DukerX Open Source Controller Boards 26 03-04-2006 07:30 AM
