Stand alone rotary table indexer.
Results 1 to 13 of 13
Thread: Stand alone rotary table indexer.
    Apr 2006
    U.K
    Default Stand alone rotary table indexer.
    Hi, in case it's of interest to anyone here, I've posted a design for a PIC based rotary table indexer here:-
    http://www.cnczone.com/forums/showthread.php?t=47007
    Hopefully it'll be of use to someone...
    Regards
    Steve
    Mar 2010
    Default Re: Stand alone rotary table indexer.
    Quote Originally Posted by kwackers View Post
    http://www.cnczone.com/forums/open-s...e-indexer.html
    Regards
    Steve
    Click here to go to the Stand Alone Rotary Indexer
    This is a new and inexpensive Stand Alone 6" Rotary Indexer already built and ready to use
    .Stand alone rotary table indexer.-rotary-indexer-controller-gif
    Dec 2007
    Quote Originally Posted by allaces View Post
    Is that Steve's design and firmware, or your own?
    cheers, Ian
    It's a state of mind!
    Jul 2014
    You have got to be kidding, 748 dollars?
    Mar 2010
    It is not Steve's design.
    The Controller is professionally designed for this type of application, and can accommodate other stepper motor Tables/Indexers and Arrangements within 24V and 3 amps. The DB9 plugs are also wired the same as the Gecko G540. Also... it's on special for $648.00 with free Shipping to Canada and USA.
    Mar 2010
    hoecken,
    Do you know of any comparable units for less money?
  7. #7
    Mar 2010
    Sorry for the double post
  8. #8
    Member Tkamsker's Avatar
    Oct 2010
    Austria
    Maybe Look at usovo.de 4th axis
    Gesendet von meinem SM-N9005 mit Tapatalk
  9. #9
    May 2015
    hoecken,
    http://www.cnczone.com/forums/arduin...are-forum.html
    Best to ask me questions there. Kwackers makes an awesome unit but if you want to roll your own, these days, the Arduino is a great platform. You can do basic indexing in as little as 150 lines of code or you can add some more professional features in 1000 lines like I have done.
    Rod Webster
    www.vmn.com.au
  10. #10
    Mar 2010
    Quote Originally Posted by rodw View Post
    The info for the Stand Alone Controller and Indexer was provided for those who "can't" or don't want to make their own.
    Thanks anyway
  11. #11
    May 2015
    Thanks anyway
    In that case, Kwackers controller sets the standard so look no further than this thread.
    Rod Webster
    www.vmn.com.au
  12. #12
    Sep 2015
    $648.00 was CAD. It's listed for $489.00 on eBay.
  13. #13
    Member nabtesco's Avatar
    Sep 2019
    This might be a little late, but there is a brand new stand alone rotary indexer that is servo driven. It claims 'infinite positionability' unlike the fixed rotary tables:
    https://www.nabtescomotioncontrol.co...ry-indexer.php
  14. #14
    sandysmith's Avatar
    Jan 2023
    Helpful discussion. A stand-alone rotary table indexer is a machine that enables precise positioning and rotation of a workpiece for tool change and/or multiple operations. This type of machine is used in machining and assembly operations, and can produce high precision parts with accuracy and repeatability. Stand-alone rotary table indexers can be used in a wide variety of applications, including CNC machining, drilling, milling, and assembly. By using a rotary table indexer, users can increase their productivity, reduce cycle times, and achieve higher tolerances.
    The use of 3D interior design can offer a number of benefits to homeowners and interior designers alike. A few of the most prominent benefits are: Increased efficiency – 3D interior design can allow for advanced visualization, making it easier for designers to create layouts and plans faster. Improved accuracy – https://the2d3dfloorplancompany.com/...ring-services/ 3D interior design rendering services can be rendered in a more accurate, realistic way, helping to create more detailed plans and better communication between designers and clients. Better space management – 3D interior design can allow homeowners to create accurate floor plans, see furniture placement, and determine the best layout for their space.
    2D floor plans provide a number of benefits, including cost savings, increased accuracy, and convenience. Cost savings are achieved by eliminating the need to hire an architect or engineer to draw up the plans. 2D plans are also faster and easier to produce compared to 3D plans, saving time and resources. https://the2d3dfloorplancompany.com/...plan-services/ 2D 3D floor plan services additionally, 2D plans are more accurate since they are drawn to scale, providing precise measurements and details. Another benefit of 2D floor plans is convenience. Because they are digital, 2D plans can be shared quickly, edited easily, printed and emailed, and stored in a cloud-based system.
    3D exterior benefits include improved visualization, easier and faster design optimization, reduced cost and time to market, increased accuracy of designs, improved communication and collaboration, and increased design options. 3D exteriors allow for realistic renderings, animations, and renderings of both the interior and exterior of a project. This allows for greater accuracy when reviewing the design, as well as providing an interactive experience for the client before construction begins. By utilizing https://the2d3dfloorplancompany.com/...ring-services/ 3D exterior design rendering services, architects are able to quickly and efficiently create, evaluate, and modify designs faster than traditional methods. This can result in more efficient use of resources and budget, faster design cycles, and more accurate results.
    Real estate rendering is a beneficial tool for both real estate agents and potential buyers. For agents, it allows them to showcase a property before it is ever built, providing an easy way to present a visual representation of the project to potential buyers. For buyers, it provides them with a way to get an idea of the property’s layout, size, and potential features before spending time and money on a physical visit. This allows buyers to understand the potential of each property and decide if it’s the right fit for them. In short, https://the2d3dfloorplancompany.com/...ring-services/ real estate rendering services help agents and buyers bridge the gap between concept and reality.
    https://the2d3dfloorplancompany.com/...or-plan-to-3d/ Converting a floor plan to 3D can provide a number of benefits. It can help with visualizing the space and give designers a better sense of the layout and flow of the space. It can also be used to help create photorealistic images of the environment, allowing designers to see how color, lighting and other elements affect the overall look and feel of the space. Additionally, 3D floor plans can be used for marketing purposes, allowing potential buyers to ‘walk-through’ a space before purchasing or renting. Finally, 3D floor plans can be used to create simulations and models, allowing people to interact with the space and even make changes to the layout without having to create a physical model.
    https://the2d3dfloorplancompany.com/...an-conversion/ 2D to 3D floor plan conversion can provide various benefits, including: Increased accuracy: 3D plans provide a more accurate representation of a space. This can be useful when obtaining measurements and planning construction projects, as they are more precise than traditional 2D plans. Improved visualization: 3D floor plans offer a greater level of detail and allow users to better visualize the space they are planning. This can be helpful when designing furniture layouts, coordinating colors and materials, and ensuring that the space can accommodate all the desired elements. Easier publishing: 3D plans can be easily published online, allowing potential buyers to view an interactive version of the space before making a purchase.
    The https://the2d3dfloorplancompany.com/...ng-price-cost/ price cost of 3D exterior rendering services varies based on the size and complexity of the project. Generally, 3D exterior rendering can range from a few hundred to several thousand dollars, depending on the size, detail, complexity and type of output format required. Factors such as the number of revisions and the complexity of the project can also affect the cost of 3D exterior rendering.
    The https://the2d3dfloorplancompany.com/...an-price-cost/ price cost of 3D floor plans can vary depending on the level of detail needed and the size of the project. For example, for a medium-sized home, the cost can range from around $500 to $1,500 USD. The cost also depends on the complexity of the project and the provider you choose to work with. Additionally, some providers may offer discounts if you order multiple plans.
    https://the2d3dfloorplancompany.com/floor-plan-samples/ Floor plan samples are typically diagrams, sketches, or images of the interior layout of a space. They may be used to help visualize the layout of a building and/or to assist in the design of the space. Floor plan samples are typically used by interior designers, architects, real estate agents, contractors, and homeowners. Floor plans are essential for understanding the arrangement of a space and can help visualize how the space will be used. Floor plans can also be used to help identify potential furniture and accessories that will fit in the space.
    Floor plan drawing offers several benefits, including helping to organize and plan a space, enabling visualization of how a space will look and feel, aiding in decision-making, and providing clarity around design and layout issues. https://the2d3dfloorplancompany.com/...wing-services/ Floor plan drawing services are especially beneficial for designing and managing complex spaces, such as retail stores, offices, and medical facilities. When creating a floor plan, designers are able to identify potential problems or opportunities for improvement before investing in materials or starting construction. Floor plans also help in determining required materials, furniture and equipment, as well as how much space will be needed for them.
    3D apartment floor plans are virtual representations of the layout and design of an apartment. They are typically generated using 3D modeling software, which allows users to create accurate representations of the apartment’s dimensions and features. https://the2d3dfloorplancompany.com/...t-floor-plans/ 3D floor plans for apartments are often used by architects, real estate agents, interior designers, and other professionals to demonstrate the layout and features of a space. They can also be used by homeowners and apartment seekers to get an idea of what their future residences might look like. 3D apartment floor plans can be viewed from any angle and often include details like furniture, fixtures, and appliances.
    Floor plan rendering is the process of creating a detailed, accurate, and realistic-looking representation of a floor plan. It allows architects, builders, interior designers, and homeowners to visualize a space before beginning construction. The benefits of floor plan rendering include Enhanced communication: https://the2d3dfloorplancompany.com/...ring-services/ Floor plan rendering services enable architects, builders, and homeowners to effectively convey their designs and ideas to each other, which can help to create a successful project. Cost and time savings: Using 3D software for the rendering process is often much quicker and more cost-effective than producing traditional hand-drawn plans. This can help to save both time and money throughout the design and construction projects.
    Floor plans are an essential tool for architects and designers when creating a living space. It allows them to clearly lay out the layout of a room or building and visualize how each element will fit together. The goal of a floor plan is to make sure that all the components come together to create a harmonious and functional space. https://the2d3dfloorplancompany.com/floor-plans/ Floor plans are important tools in helping homeowners, designers, and builders create their ideal living space.
    Floor plan design offers a number of benefits. By having a well-planned floor plan, it can make a home or office feel more organized and inviting, maximizing use of space and providing more efficient spacing for furniture and fixtures. https://the2d3dfloorplancompany.com/...sign-services/ Floor plan design services also help to provide an aesthetic look that is both pleasing and comfortable. Having an aesthetically pleasing floor plan is also beneficial for helping to increase the value of a home or office. Additionally, having a well-planned floor plan can make it easier to navigate through, minimizing the chances of getting lost or confused. Floor plan design can also help to improve safety, enabling a space to be more easily monitored and maintained.
    Creating https://the2d3dfloorplancompany.com/...d-floor-plans/ 2D Floor Plans can be a great way to get a better understanding of the layout of a space. Producing these plans gives you a 3d view of a room or building, enabling you to see the overall layout as well as specific elements like doors and windows, walls, furniture, and other features. Creating a floor plan is a skill that requires knowledge of space planning and design. It requires you to think in 3 dimensions and plan out the space, furniture, and features to get the desired result. With this in mind, it is important to ensure that the floor plan is accurate and captures all of the necessary details in order to create a space that is functional, practical, and visually attractive.
    For those living in an apartment complex, property maps can be a great tool to help keep track of the area. https://the2d3dfloorplancompany.com/...d-3d-property/ Apartment Property maps help tenants know the exact location and area of their residence, as well as provide a map that can help tenants find nearby businesses, parks and other places of interest. Property maps are also a great way for property managers to keep track of their properties and plan for future expansions or renovations. By having a visual representation of their property, it allows property managers to plan effectively and make sure that the apartment complex is well maintained.
    https://the2d3dfloorplancompany.com/...d-floor-plans/ 3D Floor Plans are a great way to show off your property to potential buyers and renters. They help people visualize a space, so they can decide if it is a good fit. 3D Floor Plans also help designers, decorators and architects visualize the layout of a room and make the necessary adjustments before construction. Creating 3D Floor Plans is the best way to accurately depict the square footage and measurements of a property, so that buyers and renters can make informed decisions on whether to buy or rent.
