Need Help! PWM circuits
Results 1 to 3 of 3
Thread: PWM circuits
    Jan 2009
    serbija
    Default PWM circuits
    Does anyone have an idea how to make a circuit between the two devices as in the picture?
    I have a PWM source which operates from 0 -2.5-5v and analog devices to the entrance between the input and GND has 5V and then output either 10V when you connect a short input and GNG have + 10v
    2.5v = 0V
    at the exit of how to do to merge these two assembly
    greeting
    Attached Thumbnails Attached Thumbnails PWM  circuits-pwm-t0-0-5v-jpg
    Registered vegipete's Avatar
    Mar 2006
    Sol 3 (YVR)
    Default Re: PWM circuits
    Some filtering turns the PWM into an analog value. Then one (or a few) op-amps can amplify, invert and offset the 0 to 5 volts to 10 to -10 volts.
    The trick though is getting a sensible output when the input is not running. If the PWM is off, what should the output voltage be, considering safe operation?
    Feb 2007
    canada
    Yes , you can use a simple RC filer on the pwm then a differential opamp to offset and double the voltage
    Quote Originally Posted by vegipete View Post
    You have the PIC output a delayed enable to the amplifier to only turn it on when its stable. Thats what i do on my step2linear
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Rachelye1's Avatar
    Aug 2019
    In addition to monitoring the output state of the power circuit, PWM (Pulse Width Modulation) circuit also provides power component control signals, so it is widely used in various high-power circuits such as switching power, motor Inverter, audio for V D-polar amplifier, DC-DC converter, and UPS.
PWM  circuits
PWM  circuits
