PIC Programing / Design
Page 1 of 8 1234 ... LastLast
Threads 1 to 20 of 160
Forum: PIC Programing / Design
Discuss programing of PIC chips here and design of electronics using PIC chips.
  1. PIC18f66J94 Compilation Error
    Started by olaf123‎, 11-29-2016 04:15 AM
    compiler, control/input/test.x, directory, e/knsingh/lube, make
    11-29-2016, 04:15 AM Go to last post
  2. diy pic16f88 cnc servo motor drive 32 bit pid
    Started by ahsameh‎, 07-03-2016 09:32 PM
    2 Pages
    1 2
    10-16-2016, 02:52 PM Go to last post
  3. Post Need Help!- Need help with PICBasic Pro Coding
    Started by khalidworks‎, 04-17-2016 10:43 AM
    cnc, code, pic, pro, programming
    04-17-2016, 10:43 AM Go to last post
  4. Need Help!- PWM circuits
    Started by aluplastvz2013‎, 01-02-2016 06:38 PM
    03-06-2016, 11:38 PM Go to last post
  5. Question Need Help!- parameters procedure of Mitsubishi M0 control
    Started by braided‎, 12-20-2015 05:26 PM
    cnc, control, mitsubishi, parameters, procedure
    12-20-2015, 05:26 PM Go to last post
  6. Rotary Table Controller debugging.
    Started by Driller2‎, 12-20-2015 02:32 AM
    12-20-2015, 02:32 AM Go to last post
  7. RT-8p8c - PIC32 based ethernet interface board for LinuxCNC
    Started by kinsa‎, 10-19-2012 08:21 AM
    2 Pages
    1 2
    10-30-2015, 09:44 AM Go to last post
  8. Stand alone rotary table indexer.
    Started by kwackers‎, 11-15-2007 05:52 PM
    10-10-2015, 12:02 AM Go to last post
    05-28-2015, 12:14 AM Go to last post
  9. Build Thread- Sense Step on Stepper ?
    Started by vangalvin‎, 04-22-2015 05:29 PM
    calculation, pick, sense, step, stepper
    04-22-2015, 07:22 PM Go to last post
  10. isolated DAC. PWM ( 20khz ) to analog 0-10Volt
    Started by visky‎, 07-29-2014 02:31 PM
    10-11-2014, 10:29 PM Go to last post
  11. PIC based DRO
    Started by BillTodd‎, 08-11-2008 05:42 PM
    10 Pages
    1 2 3 4 5 ... 10
    04-08-2014, 11:38 AM Go to last post
  12. Need Help!- DRO Design discrepancies.
    Started by ayeff‎, 01-01-2014 02:40 PM
    04-08-2014, 11:34 AM Go to last post
  13. Question Need Help!- elm chan dc servo controller
    Started by visky‎, 01-28-2014 12:06 PM
    01-28-2014, 12:06 PM Go to last post
  14. Want to get into pic programming.
    Started by 109jb‎, 05-19-2013 08:59 PM
    07-29-2013, 01:37 PM Go to last post
  15. Question Build Thread- PIC/Parallel port CNC driver code
    Started by faacuunndoo‎, 06-02-2013 02:59 AM
    down, goes, maybe, then
    07-29-2013, 01:20 PM Go to last post
  16. USART on 18F?
    Started by Al_The_Man‎, 05-18-2013 03:52 PM
    05-19-2013, 08:13 PM Go to last post
  17. ANy sucesseful xyz+spindle pic-based lpt drives?
    Started by podolskiy‎, 05-17-2010 01:07 PM
    2 Pages
    1 2
    05-17-2013, 08:06 PM Go to last post
  18. Exclamation PC Base DRO
    Started by aadityadengle‎, 02-02-2012 10:55 AM
    2 Pages
    1 2
    03-25-2013, 12:09 PM Go to last post
  19. More than one clock from the PIC to drive L297
    Started by JosipMiller‎, 02-26-2013 01:49 PM
    als
    03-03-2013, 07:31 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 4 users browsing this forum. (0 members & 4 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
