Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 01-10-2010, 05:27 PM
gorillam is on a distinguished road
Fanuc Robodrill RPC & 100 AMP Service.
Hey there people,
So it comes time that I hook up my fanuc robodrill 1998 t14.
I have some questions about what I need to do to make sure my machine runs well and I do not have any problems. I am a huge fan of the phase perfect model, but at this time I do not think I can afford the unit with all the expenses I have so far.
My problem is is that my electrician says the most he wants to pull off of my 100 amp service is 60amps for the garage 220v. My question is, would 60 amps be enough to run a 15hp rpc for my robodrill, it has a 7.5hp spindle motor.
Also my other question since there are a lot of horror stories about phase converters destroying cnc equipment. Would a phoenix phase converter unit of 15 hp on a 50-60amp breaker be sufficient, or should I just stretch my credit and go with the phase perfect unit.
It's a tricky situation and I don't want to wreck my machine, but money's tight.
I had also heard that Fanuc controllers are very voltage sensitive, would this mean rpc could destroy my machine?
Old 01-13-2010, 09:32 PM
polaraligned is on a distinguished road
60 amps is fine for a 15hp soft start converter. Run the recommended size wire from the breaker to the RPC. It is much heavier than what is necessary for 60amps alone. The initial start up surge is large and the heavier wire helps. Talk to your RPC manufacturer.
FANUC ROBODRILL NEED HELP WJ MARK Fanuc 4 01-01-2010 02:31 AM
fanuc robodrill 16M profile programming trouble edthecncman General Metalwork Discussion 0 07-19-2009 12:02 PM
Fanuc robodrill service serviceman Product Announcements & Manufacturer News 0 10-29-2008 06:16 AM
Fanuc Robodrill gregfull General Metal Working Machines 1 02-25-2007 07:25 PM
Fanuc t14ia robodrill post binzer GibbsCAM 1 02-11-2007 03:28 PM
