Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 12-28-2009, 11:21 PM
bradheiter is on a distinguished road
help picking RPC size
I bought an Abene mill --about a 6hp motor-- if I use a 10hp motor for a Fitch Williams style phase convertor will that be enough to run it well?
What if I get a 7.5hp 3 phase air compressor will it run that OK?
Brad H
Old 12-30-2009, 10:41 PM
scudzuki is on a distinguished road
It's been recommended to me that the size of the idler motor needs to be double that of the load.
Joe
Old 01-04-2010, 05:50 PM
jp425 is on a distinguished road
I built my own RPC with a 5hp idler. In the forums that I read before building it they suggested starting a tool motor no larger than 80% of the idler (10hp idler 8hp tool motor). Also read that you can run a gang of tool motors up too 120% of the idler(10hp idler three 4hp tool motors). I have not tried this. I'm running a 1hp Bridgeport with my home made unit. Building it myself with used idler, new capacitors, used contact relays and motor starters from a machine scrap yard cost me about $75.00. Wire I had on hand. Elect. drawings on the net. Saved about $600.00.
Jim
Picking a lathe size for servos I already have Michael M Servo Motors and Drives 0 10-09-2009 01:30 PM
Need help picking a VMM Tony-JL Want To Buy...Need help! 2 03-03-2008 08:38 AM
need help picking software reeftoker75 General CNC (Mill and Lathe) Control Software (NC) 4 03-14-2006 12:19 AM
help picking a cnc machine lsw11 General Metal Working Machines 5 08-26-2005 09:54 AM
Help picking a Driver met4life Stepper Motors and Drives 5 03-22-2005 05:43 PM
