| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
| These are basically intended to prevent currents induced or imposed on motor rotors that may leak to ground through the shaft bearings. If this happens in any great degree, the bearing races and balls or rollers become pitted. This used to be prevalent with commutator or slip ring fed armatures where a ground leakage occurred on the wound armature. Now supposedly the same effect can occur on variable frequency drives, where high frequencies are induced in the rotor. The diverter ring is supposed to by pass or shunt the current that would otherwise flow to ground through the bearing. Al.
| Distance rings? | zephyr9900 | Tormach PCNC | 29 | 05-29-2012 08:46 PM |
| Fixing rings? | JayH1119 | CNC Tooling | 3 | 01-12-2009 01:43 PM |
| Fire Rings | millerrocks06 | Product Announcements & Manufacturer News | 8 | 03-31-2007 03:08 PM |
| Ferrite rings? | murphy625 | General Electronics Discussion | 5 | 05-30-2005 06:43 PM |
| Making Custom O-Rings | NeoMoses | Welding, Brazing, Soldering, Sealing | 6 | 05-13-2003 10:07 AM |
