| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
I am installing new controls on a knee mill and would like to install a VFD so I can do tapping. At the very least I need to use a floating tap head, although ridgid tapping would be ideal, once Mach 3 gains support for it or if I possible go with another program I may integrate it. The motor is 3HP and I would prefer a conver that can run on 220v 1ph. Which do you guys suggest? |
| Hi Green, I am very happy with my Hitachi SJ200. It is very programable and has sensorless vector control which means you don't lose torque at lower rpms. You don't get full hp at low speed but it is much beter than Hz/v control. It takes in 240v 1ph and outs 3ph. I am using it under full cnc control. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| The SJ200 Hitachi is an excellant choice ! I just converted from a 2 pole motor and L200 to a 4 pole motor and the SJ200 and have torque down low and am running the motor to 120 hz for top rpm. You will need the low end torque to be able to tap with using your tapping head, and as for rigid tapping using a hard driver NO SOAP yet with mach3 What ever inverter drive you choose, make certain it is a "CONSTANT TORQUE" model
__________________ Don IH v-3 early model owner |
| CAD CAM recommendation | lipolad | General CAM Discussion | 1 | 03-06-2008 10:17 AM |
| Cam Recommendation | dgoddard | General CAM Discussion | 0 | 06-15-2007 08:38 AM |
| CAD/CAM recommendation | split63 | General CAM Discussion | 9 | 06-11-2007 05:59 PM |
| Recommendation Please | SPEEDRE | Autodesk Software (Autocad, Inventor etc) | 0 | 02-12-2007 05:33 PM |
| mill recommendation | rickyt | Milltronics | 7 | 05-08-2006 11:07 AM |
