Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 12-14-2009, 11:47 AM
jimjovan is on a distinguished road
Seeking advice on GE/Fuji AF-300 VFD
Can anyone give me some advice on this VFD (GE/Fuji AF-300 E11)? I am looking at using it for the 2.2 KW, 3 hp motor on my Shizuoka ST-N.
Attached is the 2 page brochure.
I would think it should work for my application. It is a cheaper drive (no encoder input), but I wasn't planning on doing rigid-tapping anyway.
Is there any big disadvantages to this drive?
Old 12-14-2009, 02:30 PM
Al_The_Man's Avatar
It takes up to 3hp in single phase so it should work.
The encoder on the motor back to the drive is used for precise speed control and torque down to low rpm, for rigid tapping you would also need an encoder on the final spindle shaft back to the CNC controller, or Z axis on a mill.
Old 04-04-2010, 08:21 PM
dan_barber is on a distinguished road
Fuji used to manufacture GE's AF-300. But now Fuji has their own version called FRENIC Mini.
http://www.ctiautomation.net/FUJI-FR...-Inverters.htm
Prospective Machinist Seeking Advice Septimius CNCzone Club House 8 02-26-2010 12:57 PM
SEEKING ADVICE kling8 WoodWorking 3 11-19-2009 02:19 AM
Need Help!- Seeking advice on installing a QCTP Thazul Mini Lathe 6 03-28-2009 01:53 AM
New Machine Build- Seeking advice on motor/electronics package endgrainguy DIY-CNC Router Table Machines 3 02-11-2008 10:33 PM
Seeking Minilathe QCTP Advice HankB Mini Lathe 1 02-08-2008 08:29 PM
