Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 11-28-2009, 12:36 PM
Shanghyd is on a distinguished road
Pehaka horizontal saw wiring diagram
I need help with changing from 440 to 220.
I have one wiring diagram, Its in German though. I scanned it and have inserted it.
There are 2 motors that need to be changed over. The first motor is the first picture and the scanned wiring diagram.
The 2nd picture is the 2nd motor.
Any help is appreciated.
Here is the scanned diagram for the wires in the first picture.
Hohe Spannung is "High" and the other one Niedrige Spannung is "Low"
And here are the wires for the 2nd motor without a diagram.
Old 11-28-2009, 03:38 PM
Al_The_Man's Avatar
The first motor is fairly straight forward, the jumpers just need to be changed, the second appears to have 6 wires coming in, the reason may be is it possible that this motor may have been started with a star-delta starter or a two speed controller?
Is the wiring still present for the second motor, if so it may need a bit further investigation as to what feeds it.
Old 11-28-2009, 08:04 PM
The jumpers as in the little metal plates? or would the 3 wires move to the 3 points opposite where they are connected now?
Old 11-28-2009, 10:20 PM
Al_The_Man's Avatar
If the top motor is connected for 440 now, then the jumper plates would be moved up in the picture and the bottom three would be jumpered across horizontally.
The three phase in would go to each of the three jumper plates.
IOW, the terminal box is upside down to the picture.
Old 02-19-2010, 12:00 PM
Got another issue
I have one more small issue before I can move on with this project.
I got a new hydraulic solenoid valve.
Electric stuff is not my strong point obviously. I need some help in wiring up the solenoid valve.
The saw operates like this:
Press one button to turn on the hydraulic pump. The pump will stay on until I hit a seperate button to turn it off.
There are two different buttons for the two different solenoids.
I have no idea what combination of buttons will work to raise and lower the saw. I'm not sure if I would need to hold the button to keep the solenoid energized or if I would need to press another button to disengage the solenoid.
There are 3 wires coming from the saw. Green/yellow, Blue, Brown. I've figured out the grn/yellow is ground.
Old 02-19-2010, 12:45 PM
Al_The_Man's Avatar
First you would need to know whether you have to retain power to the solenoids while in position, or if on only until up or down is required.
This decides the logic required, the most simplest is if sol. power is only need to raise and lower with no retention.
You could do this just by applying power to one or the other in turn and see the results.
Wht-Blk or Red-Orange.
Old 02-19-2010, 01:50 PM
I applied 21V+ to White and grounded the other wire. The directional light came on and stayed on. I did the same with the other wire combination and the other directional light came on.
The same button that turns off the hydraulic pump turns off the solenoid. There is also a round switch that turns and can be in an "in" state or an "out" state.
I used my multimeter and hooked the black probe to the grn/yellow wire. I hooked the red wire from my meter to the blue wire coming from the saw. When I pressed one button on the control panel the meter read 26V+ When I pressed the other button the 26V+ went to less than 0V and fluctuated. I tried the same procedure with the brown wire coming from the saw. No button combination got any + volts from the brown wire.
Saw Start and Saw Stop should be Blade Start and Blade Stop instead.
Old 02-19-2010, 11:14 PM
I did some wire tracing and came up with some more info.
The 3 wires come from the solenoid and connect to a relay. There are 2 relays jumpered together. I'll upload some pictures tomorrow. Only one relay engages and disengages when I push the buttons. There is something that looks like a diode that is wired into the relays.
Another thing that struck me as odd was that the green/yellow wire doesn't go to ground. It goes to the relay. There is also a red sleeve over the green/yellow wire.
Old 02-20-2010, 02:55 PM
Al_The_Man's Avatar
This is why I mentioned to get the required logic, as it sounds like you might have the solenoids kept energized by each relay and they are interlocked so only one can be energized at the same time.
It would be best to carefully reverse-engineer it and draw a schematic up based on the results, then it can be connected properly.
I did not see any previous mention that the solenoids were 24v? Is this AC or DC?
Old 02-20-2010, 07:12 PM
They are 24V dc. I'll try to trace the wires and come up with a schematic
The soleniods have to be ennergized for the fluid to move.
I only have one of the original solenoids and it was the one to let the saw down. To raise the saw I would turn on the pump and push in on the pin where the missing soleniod was.
To lower the saw I would turn on the other solenoid and adjust the bleed off valve. If I turned on hydraulic pump while the solenoid was on the saw would feed downward.
I have a thread about it on another website that might help explain it.
http://www.cnczone.com/vb...ic-saw-195208/
  #11   Ban this user!
Old 03-08-2010, 01:14 PM
I'm still working on this saw. I've worked out some of the wiring and created a dxf. Can someone look at it and let me know what information is needed to get this thing working right? Do I need to trace the wires all the way to the switches?
Old 03-08-2010, 03:12 PM
Al_The_Man's Avatar
I will look the DWG and get back, the first thing you want to do is get rid of those selenium rectifiers.
Need Help!- wiring diagram prabhu58 General Metal Working Machines 0 11-10-2009 10:56 PM
320 ERR/RES wiring diagram schwinndk Gecko Drives 2 10-22-2009 05:33 AM
help with wiring diagram for C6 CNC JDsto Syil Products 6 01-09-2008 06:37 PM
Wiring Diagram SCHMEOW General CNC (Mill and Lathe) Control Software (NC) 1 10-20-2007 11:40 PM
