| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
Has anyone come across this in the past A CNC I've just go in my posssion has 3 AC motors as the drive AXIS motors They are 3 Phase 2kw units with an extra shaft out the back for an encoder. At first I didnt think that it could be right and checked the drives as well as motor codes. They are a standard Yaskawa unit. I couldn understand this being common place in a production line unit. The other wierd part is there doesnt seem to be a DC brake fitted anywhere. Which to me would make perfect sence in this situation? Thanks |
| Yes most industrial AC servo motors are 3P x 200V I have used 100s of them if you have Yaskawa thay are one of the best there is. The machine usally has a brake only on the Zaxes sometimes its built into the motor sometimes its built into the machine If you have a brake in the motor it will be about 60/70mm longer than a motor that does not have a brake
__________________ Mactec54 |
| Can any 3 phase motor be run with a VFD? | tootalew | Phase Converters and VFD | 33 | 06-04-2010 07:20 AM |
| fitting a 110v or 220v single phase spindle motor on a 3 phase machine | mwood3 | Benchtop Machines | 12 | 10-12-2009 09:53 PM |
| Can I convert single phase motor to three phase? | Jim Estes | Phase Converters and VFD | 30 | 01-24-2009 02:41 AM |
| Help with 3-phase motor | protrxrptr17 | Phase Converters and VFD | 5 | 07-08-2008 02:24 PM |
| 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ... | kochevnik | Stepper Motors and Drives | 6 | 10-22-2006 10:48 PM |
