Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 10-15-2009, 10:44 AM
QTR55 is on a distinguished road
our current is 220 and i want u to advice
Hi
our current is 220 and i want u to advice me what is the suitable transformer to my machine wich can fit for it without any problems caus i order additional kit( Small-Mill Deluxe CNC kit PREMIUM BALLSCREWS ) the machine draw is 110 according to the american current and if its possible to email me the ful nam of the suitable trans who can fit correctly without any problems.
waiting for your reply.Thank you.
G0619 6" x 21" Mill / Drill
http://grizzly.com/products/G0619
Old 10-15-2009, 11:04 AM
Al_The_Man's Avatar
The wattage or current (at 110vac) of the machine also has to be known.
Old 10-15-2009, 05:09 PM
nikodell is on a distinguished road
This is the specs of the machine he posted:
MODEL G0619 6" X 21" MILL / DRILL
Product Dimensions:
Weight............................................................................................................................................................. 364 lbs.
Length/Width/Height....................................................................................................................... 27 x 30 x 33-3/4 in.
Foot Print (Length/Width)............................................................................................................................ 16 x 13 in.
Shipping Dimensions:
Type.......................................................................................................................................................... Wood Crate
Content........................................................................................................................................................... Machine
Weight............................................................................................................................................................. 437 lbs.
Length/Width/Height............................................................................................................................ 33 x 32 x 42 in.
Electrical:
Power Requirement............................................................................................................ 110V Single-Phase, 60 Hz
Switch............................................................................................................................................... Forward/Reverse
Switch Voltage....................................................................................................................................................... 110
Cord Length........................................................................................................................................................... 7 ft.
Cord Gauge...................................................................................................................................................16 guage
Minimum Circuit Size....................................................................................................................................... 15 Amp
Plug Included......................................................................................................................................................... Yes
Included Plug/Outlet Type.......................................................................................................................... NEMA 5-15
Conversion To 440V................................................................................................................................................No
Motors:
Main
Type............................................................................................... IP44, Class F, Brushless DC Motor (BLDC)
Horsepower......................................................................................................................................................1
Voltage......................................................................................................................................................... 110
Prewired....................................................................................................................................................... 110
Phase....................................................................................................................................................... Single
Amps.............................................................................................................................................................. 12
Speed.........................................................................................................................................................3500
Cycle.............................................................................................................................................................. 60
Power Transfer .................................................................................................................................. Belt Drive
Bearings.....................................................................................................Sealed and Permanently Lubricated
Old 10-16-2009, 08:17 PM
Ark1 is on a distinguished road
Converter needed.
If you go to ebay and type in "converter 220" you will find simple box type converters that will allow you to just plug in to your wall socket and then plug your CNC machine into it. Looking at the electrical specs. You will need a 1500 watt or VA converter. I was looking at transformers today on ebay and came across serveral units that would suit your needs.
TonyK.
USB max current? Brenck General Electronics Discussion 5 06-04-2009 12:16 AM
New and in need of some advice... well alot of advice! GoonShoes Bridgeport and Hardinge Mills 9 05-30-2007 07:03 AM
current over bbrreid General Electronics Discussion 4 08-01-2005 04:43 PM
Drive current to low? CRFultz Gecko Drives 7 04-29-2005 10:33 PM
