Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 09-22-2009, 07:49 PM
stevespo is on a distinguished road
Huanyang HY02D223B goes POP!
I was running a job the other day when I heard a loud POP!, and noticed that my spindle was slowing down. I walked over and hit the EStop, and sure enough the display on the VFD was off. There's wasn't anything obviously wrong (ie. no smoke, no flames, etc).
I wasn't sure what happened, so I thought that maybe it was just the breaker. I checked the panel and the 20A breaker had been tripped. I looked at all my connections and everything was tight.
So, I flipped the breaker back on and went over to the VFD. When I applied power to the VFD, the breaker for the entire 100A panel clicked off! Oh boy. I'm not sure what happened, but the VFD is toast. I'm going to send it back to China for replacement, but I'm seriously thinking about upgrading to a Hitachi XJ200 or SJ200 as my primary VFD.
Any thoughts on what happened? Any ideas? This has functioned flawlessly for 6 months, running small jobs all the time. No problems at all until now.
Steve
Old 09-26-2009, 02:12 PM
LazyMan is on a distinguished road
Cant really help but, I have purchased the X200 3 hp VFD for my 2.2kw Chinese spindle instead of the Huanyang one out of the fear of reliability problems. After all, the price difference between the two VFDs is small. I'm knew to all this so I am trying to figure out how to set it all up. I guess the only disadvantage is that most on the zone seem to have the Huanyang and there is not as much forum support if you are a newbie.
Help with Huanyang HY02D223B stevespo Phase Converters and VFD 248 03-15-2012 06:16 PM
Need Help!- Help Help Help - Huanyang VFd and spindle PsychoPig7 Phase Converters and VFD 7 12-04-2011 09:19 AM
Need Help!- Huanyang HY02D223B 2.2Kw VFD gillyhyde8888 Phase Converters and VFD 7 09-11-2009 06:46 PM
HY02D223B and GDZ-10 PLS HELP 15mgtar DIY-CNC Router Table Machines 0 08-21-2009 12:32 AM
Need Help!- Could someone post there setting for a HY02D223B Ed Williams DIY-CNC Router Table Machines 6 05-20-2009 12:23 PM
