| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
I just got a series 2 Bridgeport and am re-doing the controls. I only have single phase in my shop and have 3 VFD's running already and am very familiar with them. What I don't know much about is CNC control of a VFD. I want to be able to do ridgid tapping. Should I use a vector VFD that requires an encoder to operate, and put an encoder on the spindle, or can I add an encoder later and just tie it into the machine control with a standard VFD? Which one will give me more options? I'm leaning towards the vector/encoder VFD type, like this one. http://cgi.ebay.com/7-5-HP-230V-VECT...d=p3286.c0.m14 I would appreciate you guys thoughts on this. |
| You did not say what Controller you have? AFAIK, Mach does not do rigid tapping? Commercial machines use a spindle motor with fairly tight control, this means either a pulse wheel or encoder on the motor shaft for precise speed control. The Z axis is then geared to the spindle rotation via an encoder driven off the final spindle shaft. Al.
| Well if EMC supports it you maybe in luck, personally I would prefer to have one on the motor as well, the VFD link mentions that it has encoder option, does this mean it is a must with this model or will it operate without it in the vector mode in the mean time? Also, maybe a query in the EMC forum as to rigid tapping may help. Al.
| Newbie- Help with choices | Soloratov | General Metal Working Machines | 3 | 02-06-2009 06:45 AM |
| New Machine Build- X2 CNC choices | sansbury | Benchtop Machines | 27 | 07-30-2008 09:23 AM |
| Choices, Choices | Stewbaru | Benchtop Machines | 91 | 07-09-2008 03:39 AM |
| Career Choices | jhwatts | CNCzone Club House | 6 | 01-29-2006 07:25 AM |
| choices, choices | zcases | Phase Converters and VFD | 2 | 04-27-2005 02:48 PM |
