Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 09-11-2009, 05:01 AM
Dougal is on a distinguished road
VFD and 3 Phase vs DC.
So what are the pros and cons of a VFD vs DC motor and drive?
3 phase motors and cheap and plentiful, VFD's are a good price and come with logic inputs.
Just considering future options.
My X2 CNC Brain Build: http://www.cnczone.com/forums/showthread.php?t=61345
Gecko G250 wiring errors: http://www.cnczone.com/forums/showthread.php?t=68960
Old 09-27-2009, 04:55 PM
Anyone with an opinion or idea?
Old 09-27-2009, 05:16 PM
LeeWay's Avatar
LeeWay is on a distinguished road
When I did my mill and lathe, there was an abundance of viable DC motors and controllers that would work great. Cheaper than the VFD alternatives. I didn't need anything large either.
DC motors are now a little more scarce. Some say it's because they generate power as well and they are being scarfed up for wind turbine projects.
Today if I needed another, I would go with VFD and AC motor. They are reasonably priced now too. It seems they were a little more costly when I was looking.
Lee
Old 09-27-2009, 05:22 PM
Al_The_Man's Avatar
Pros and cons? alot depends on availability and what you spindle features you expect.
For example, if using a DC servo motor, these often come with tach feedback, this gives you precise control that only a VFD with PWG or encoder on the motor will give you.
Surplus DC motors and SCR controllers can also be obtained cheap.
Both VFD and DC SCR controllers usually have +-10volts input.
If you use Mach, this means a PWM to analogue converter.
If you get a 4 quadrant DC drive, you get +- analogue control and dynamic braking.
Modern CNC machines typically have a VFD style drive to induction type 3 ph motor, but have a pulse wheel feedback from motor to drive together with dynamic braking for precise control.
Old 09-27-2009, 05:38 PM
Thanks guys.
I was looking at future upgrades of my lathe and mill. My lathe is single phase AC and I noticed several people have upgraded them to DC for variable speed. But for me a Telemecanique (or similar) VFD is a far cheaper and more versatile solution.
Small 3 phase motors are also cheaper and available in a bigger range of power and speed ratings than DC motors here.
I just wanted to make sure I wasn't missing anything important.
Old 09-27-2009, 05:42 PM
Al_The_Man's Avatar
I have used the Telemecanique Altivar series, so far they have done a nice job.
Newbie- 2 phase driver & 4 phase 6 wire stepper HELP! mark in aus Stepper Motors and Drives 2 06-02-2009 12:31 PM
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
1 phase Vs 3 Phase power what is the difference????? KustomKoncepts Commercial CNC Wood Routers 12 11-17-2007 10:34 PM
3 phase transformer on single phase? jevs General Electronics Discussion 4 03-19-2005 11:25 AM
2 phase vs 4 phase stepper motors Don C General Electronics Discussion 1 05-26-2004 01:40 PM
