Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 09-05-2009, 09:01 AM
racear*2865 is on a distinguished road
VFD fault from Rotary Converter
To Any One That can Lend assistance
I have a 15hp rotary converter that I constructed and I am attempting to hook it to a 7.5 Delta variable frequency drive. As I apply power to he vfd, it will immediately fault from the wild leg. If I measure the individuals legs to ground. They read T1--118, T2--120volts andT3--185. T3 is the developed wild leg. When the VFD sees that leg it faults. I do not know how to get around this. I tried adding run capacitors, but it raised the T3 voltage even higher. Can any one lend me some knowledge
thanks
racear
Old 09-05-2009, 09:05 AM
Al_The_Man's Avatar
It is probably sensing the high voltage, try reducing the run capacitor value, this should drop the 3rd leg down.
Old 09-05-2009, 12:38 PM
Al
I do not have any run capacitors in the circuit. I have already removed them. That is why I dont understand this thing
racear
Old 09-05-2009, 01:18 PM
Al_The_Man's Avatar
Thats unusually high without any caps, are you using a 2 pole motor (~3500 rpm) for the RPC.?
Old 09-05-2009, 05:45 PM
Al
No it is a 1750 rpm
Old 09-09-2009, 12:15 AM
bocko912 is on a distinguished road
I just finished a 10hp RPC and balanced it within 3%. I am using it on a 5HP cnc with a V1000 Yaskawa VFD. My voltage to ground on T3 is 216 volts and T1 is 118 T2 is 120. More important is your balance you must have run caps from T1 to T3 and T2 to T3. I ended up with 80MFD on T1 to T3 and 44.5 MFD from T2 to T3. This gave me a reading of 250 to 251 volts from T1 to T3 and T2 to T3. My single phase in is 244 volts across T1 and T2. My Idler is a 240/480 volt 3ph Delta 1750 RPM from an old air compressor. It balanced perfectly. I don't think your drive is faulting from a high leg because true 3phase 240 delta has a wild leg that is 240 volts to ground and 2 legs that are 120 volts to ground. Let me know if this helps
John
Old 09-11-2009, 11:18 AM
deanq is on a distinguished road
bocko912 is correct. Balance your RPC phase-phase, not phase-ground.
Old 09-13-2009, 10:03 AM
Fellows
thanks for your inputs.
will reconnect the run capacitors and re balance. Is it possible that the VFD is seeing the imbalance and faulting
racear
Old 09-13-2009, 02:12 PM
Does the drive fault just booting up the machine or does it fault when you try to run the spindle?
John
Old 09-14-2009, 09:50 PM
It faults when I boot up the VFD
racear
  #11   Ban this user!
Old 09-16-2009, 09:37 AM
I have balanced the 3 legs to within 3% underload but it continues to fault
racear
  #12   Ban this user!
Old 09-16-2009, 12:05 PM
You should balance the RPC with no load first then after its balanced under no load take voltage and amperage readings apply your load and then take readings again. Your voltage readings should decrease and amperage readings should increase evenly across your phases. Is your VFD new or used?
CNC rotary Converter racear*2865 Phase Converters and VFD 5 08-11-2009 05:15 PM
running off rotary phase converter Joe Miranda Milltronics 3 04-14-2008 09:19 AM
760-22 with rotary phase converter? tstom Bridgeport and Hardinge Mills 1 03-03-2008 12:34 PM
HELP rotary converter for air compressor gman1487 General Electronics Discussion 0 06-03-2007 11:22 PM
AC unit -> rotary phase converter? loves80z Phase Converters and VFD 17 11-02-2005 04:23 PM
