Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 08-08-2009, 07:11 PM
dlenardu is on a distinguished road
What kinda phase converter needed?
I just bought a Harig Super 618 surface grinder. It is a 1 hp 3 phase motor. I'm wondering what kind of phase converter I need. Will a static converter be sufficient or do I need to go to a rotary?
Old 08-08-2009, 07:54 PM
Al_The_Man's Avatar
What voltage? static or rotary would most likely work.
Have you considered a VFD? Even if it is just fixed to 60hz.
Old 08-08-2009, 09:44 PM
Sorry, it's 220v. Is a VFD cheaper than going either rotary or static?
Old 08-08-2009, 10:30 PM
Al_The_Man's Avatar
For a 1 hp it probably would, if you just need it for one machine.
Old 08-10-2009, 07:14 AM
I see that with a static converter I only get 2/3 hp. With a VFD will I get full Hp? Also when buying a VFD do I need to get double the HP size like with a RPC?
Old 08-10-2009, 08:40 AM
Al_The_Man's Avatar
Check with the manufacturer, some quote a derating % when used on 1 ph.
Something like a surface grinder kept at 60hz I don't think would be a problem.
wtb: 20 or 30 hp phase perfect phase converter gaugemate Want To Buy...Need help! 0 10-23-2008 12:06 PM
Help Needed Phase Balancing a Rotary Converter Tayloned Machine Problems, Solutions , Wireless DNC, serial port 8 02-05-2008 01:34 PM
DIY 3 phase converter blackbeard52 Phase Converters and VFD 2 01-16-2008 09:46 PM
DIY phase converter? wyobmf Phase Converters and VFD 9 07-26-2006 04:37 PM
3 phase converter? jevs General Metal Working Machines 5 02-16-2005 01:40 PM
