Results 1 to 6 of 6
Thread: VFD for Denford Orac
    Jan 2008
    I have a denford orac lathe and the spindle motor is 0.37Kw 1400 rpm 380-420v. what specs do i need to look for when buying a vfd for this motor? Any help would be great.
    Thanx
    Adam
    Jan 2008
    No one has any advice?
    Adam
    Dec 2003
    Do you have 380 or 440 3 phase?
    You just need one that covers the rating of the motor.
    If you are hoping to run off 1 phase VFD input, you may be out of luck if the motor is 440v.
    Jan 2008
    its actualy a 230v 3 phase, so if i get a vfd that is 110 single phase input, and 230 3 phase output, and it has a high enuff amp rating (2.5) for this motor then it will work?
    Dec 2003
    I would purchase the 240v model and hook it into 240 1 phase, check the manufacturers literature as to any de-rating when used on 1 phase, some require it, some do not.
    So it may require a slightly larger capacity, depending on make/model.
    Jan 2008
    THank you for your help!
    1. Denford Orac
      By Twisted in forum Europe Club House
      Last Post: 07-10-2012, 05:09 PM
    2. Denford Orac Electronics
      By adbradley in forum Benchtop Machines
      Last Post: 08-03-2009, 03:00 PM
    3. Need Help!- Denford Orac Conversion to MACH3
      Last Post: 08-03-2009, 04:42 AM
    4. Need Help!- Denford Orac Conversion to MACH3
      By adbradley in forum Controller & Computer Solutions
      Last Post: 07-29-2009, 01:59 AM
    5. ATC for Orac lathe
      By mikemill in forum General Metal Working Machines
      Last Post: 03-09-2009, 05:12 PM
