Results 1 to 3 of 3
Thread: Spindle speed at 25% on HY02D223B
    Feb 2005
    UK
    I bought one of the VFD's HY02D223B with a 1.5KW air cooled spindle motor from Love Happy Shopping on Ebay.
    2 Issues arising so I could use a little help.
    Firstly,
    I'm avised by the seller to keep the spindle speed below 100Hz otherwise damage to the motor could arise due to through overheating.
    Secondly,
    The Max spindle speed i can get seems to be around 13000rpm. The parameters for the following registers were set.
    013 was set to 08
    005 to 400
    004 to 400
    003 to 400
    Supply to the VFD is 220-240vac UK standard.
    Can anyone advise.
    thanks
    George
    Apr 2009
    George--Are you sure of the max RPM? Have you actually checked it with a tach? I found a parameter that had to be changed to get the readout on the VFD to reflect the actual RPM. This is parameter 144 "Rated Motor Revolution" and it seems to mean "per 100HZ". So I set it to 3000 and the readout agrees with my electronic tach.
    Prior to the change my readout was showing about half of actual RPM.
    Hope this helps.
    Nelson
    Edit--"per 100HZ" should read "per 50HZ"
    Registered MonoNeuron's Avatar
    Aug 2003
    Hi George,
    Have you got your spindle set up yet?
    The MIN spindle speed is 100 Hz NOT the max. It, the spindle, will get hot because it's not spinning fast enough for the fan to cool the motor.
    Mhastings2004 has written a lot on this and is detailed in some of the newer posts.
    have a read.
    Rich.
    I am not completely useless.......I can always serve as a BAD example.
  1. Help with Huanyang HY02D223B
    By stevespo in forum Phase Converters and VFD
    Last Post: 03-15-2013, 12:46 PM
  2. Need Help!- Could someone post there setting for a HY02D223B
    By Ed Williams in forum DIY CNC Router Table Machines
    Last Post: 05-20-2009, 01:23 PM
  3. spindle speed
    By Mike Boarman in forum Machines running Mach Software
    Last Post: 11-27-2006, 10:37 PM
  4. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport and Hardinge Mills
    Last Post: 08-08-2006, 04:29 AM
  5. Low speed spindle?
    By cbass in forum General Metal Working Machines
    Last Post: 02-25-2005, 04:38 AM
