Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 07-31-2009, 08:32 PM
db113 is on a distinguished road
Use of Momentary Switches on VFD
I have a Mitsubishi VFD model FR-024 that I want to use to power my three phase jointer. I have the jointer running with the VFD but I want to add external switches for on and off. I have an enclosure with AB momentary switches labeled Start-Stop. However, I can't figure out how to set the VFD for use with momentary switches and I dont have any continuous open/closed switches. Can anyone suggest how to configure the VFD to accept the momentary push button switches?
The FR-024 manual is at: http://www.meau.com/Files/IB_NA_66522-C.PDF
Thanks,
Don B.
Chattanooga, Tennessee
Old 07-31-2009, 09:00 PM
Karl_T's Avatar
Karl_T is on a distinguished road
On my lathe with a mitsubishi VFD I installed a motor contactor in front of the VFD. Then wired the start PB to close the contact and latch it in and then stop button to break the latch.
Karl
Old 07-31-2009, 10:13 PM
Al_The_Man's Avatar
See page 28 note 3 and par 59. This will set it for momentary start.
Old 08-01-2009, 09:36 AM
OK, I know "nothing difficult is ever easy".
But, here is what I have.
I was using a manual for the FR-A024 that I had printed out a few years ago. My printed manual did not have the reference to Pr 59 (anywhere-not mentioned in the manual) or the Note 3 that appears on page 28 which is now referenced in the current, online manual from the Mitsubishi site. So, I printed out a new manual from the online Mitsubishi site to keep in the shop for future reference. I went off to make the newly discovered adjustment which I was sure would allow operation with momentary switches. Got everything wired-up just right and then attempted to program PR 59. But, my FR-024 doesn't seem to know anything about PR 59. When I attempt to read the PR 59 parameter, I get an "err" code. I have two other FR-024 VFDs in my shop and none of the three will recognize PR 59.
Any suggestions?
Either I'm doing something wrong (likely) or I have three early versions of the FR-024 which didn't allow PR 59 and I suppose no capability to use momentary switches.
More help needed.
Thanks in advance.
Don Brookshire
Old 08-01-2009, 11:11 AM
Al_The_Man's Avatar
It is possible you could be out of luck with an earlier version, I notice in the back of the current manual they mention Revisions, whether this is just to the manual or both Manual and VFD is a guess.
If your manual does not mention the Par 59 or show the hook up for momentary start then it may have been a firmware change on later models.
Unfortunately most Mits VFD's do not have a 24vdc output for an external relay, but you could supply your own, you just need a 24v bell transformer and a small 24vac double pole relay, or two if you need to reverse.
You could use the standard common P.B. start circuit and use a latch contact in parallel with the start P.B.
Old 08-01-2009, 11:40 AM
Thanks Al.
Do you know a source that could answer the question about my specific model. It seems unlikely to me that all three of my Mits VFD's would be an early model w/o the PR59, but it is, of course, possible. Does Mits have a support forum or tech support available through email? My experience has been that these really big companies are less receptive to the consumer, unless the consumer is a really big customer.
Thanks again for the help.
Don
Old 08-01-2009, 11:55 AM
Al_The_Man's Avatar
Mitsubishi in both US and Canada are very good at answering support questions, give them a call in Chicago, I may have an email address for VFD support as I had an issue some time ago with some VFD's I had installed.
I will try and look it up today.
If it is a much older model, you may not get a firmware update, if this is the problem.
Old 10-10-2009, 10:26 PM
More VFD help needed
Well I never did solve the problem with the Mitsubishi VFD. I think my Mits drives must have predated the use of Parameter 59.
However, I had this thing solved by using a TB Woods VFD that I had but that drive blew.
So, I bought a Toshiba VF-nC1 VFD and now Im trying to get the Toshiba to work. Well, I'm back at the same spot as before; I cant figure out how to program for a momentary switch.
If anyone could help, it would be great.
The manual is at: http://www.mlatsos.gr/toshiba-manual/VFNC1.pdf
All suggestions appreciated.
Don Brookshire
Old 10-11-2009, 12:11 PM
Al_The_Man's Avatar
If it does not have momentary start input option, (I could not see it), you could set up a relay using the standard start stop circuit using a momentary P.B. for start another for stop,
The relay uses a retaining contact in parallel with the start P.B.
Old 10-11-2009, 01:26 PM
Thanks AL.
That might be my best option.
Could you outline what would be needed for the relay and how to do it?
or
could you route me to a site that would be helpful in setting up the relay?
Thanks,
Don B.
Old 10-11-2009, 02:05 PM
Al_The_Man's Avatar
See the simple circuit on page 6, the O.L. contact can be ignored and deleted.
http://literature.rockwellautomation...d001_-en-p.pdf
The relay M can be any small double pole relay, 120vac or 24v ac/dc circuit, one contact as shown across the on PB and the second would be across your VFD input terminal.
  #12   Ban this user!
Old 10-11-2009, 05:42 PM
Thanks AL!!
Those diagrams will be helpful.
Don B.
Momentary Switch SPEEDRE General Electronics Discussion 3 08-06-2007 06:34 PM
Momentary Glitch or Glimpse of Great New Feature? Mike Nash Forum Questions or Problems 0 05-01-2007 08:19 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
