Results 1 to 6 of 6
Thread: CNC rotary Converter
    Apr 2007
    Usa
    I built a rotary phase convert 15hp using an older all copper motor(probably today's 20hp). I have a 7 1/2hp spindle 3phase CNC mill. Because of the imbalance on the wild leg, having problems starting it up. Have 5 other 3 phase machines all with different hp motors, but none give me problems. Have a 50 mfd capacitor (run) across t generated leg to balance but still doesnt help the CNC mill. Any suggeestions??? Please
    racear
    Jul 2005
    On most CNC the three phase is rectified for a DC supply that is used for the servos and spindle drive; these do not drive directly off the incoming supply.
    The internal electronics are run off one of the legs of the incoming supply and this is often through a transformer down to 120V. If you have it connected so the wild leg is the one being used by the internal electronics that could cause problems ; perhaps you can just switch the incoming lines to try all the possible combinations to see if this helps.
    It is possible you will not solve the problem because some CNC machines want a closely balanced three phase input which is not really easy to get from a simpl rpc.
    Apr 2007
    Usa
    I had already made sure that the wild leg was not run thru the electronics. Only the spindle is off wild leg. But the machine apparently looks for balance of the legs. Is there any thing that I can do (rework or add too) to my RPC that will help it. Is there a controller or other means to get my RPC to be closer.
    again thanks for inputs
    racear
    Apr 2008
    I had to have a custom multitap transformer built for my lathe to keep it from crashing when I turned the cnc mill spindle on.
    It seems that when you apply a load on the rotary phase converter the artificial line collapses a fair bit for a moment.My fanuc control trips out but my Dynapath Delta control never quits.
    New tech can't take the fluctuations.
    Good luck
    May 2008
    How wild is your wild leg? Are you equipped to determine how much its dropping?
    If it is the simplest mode of detection, there might be a "phase monitor" relay that is simply connected to all three incoming legs, and provides a contact as a signal to the rest of the controls. These phase monitors almost always have a sensitivity adjustment. They also usually detect phase order, so if you swap two of your incoming phases it might drop out as well.
    Let us know what you find.
    Oct 2007
    Quote Originally Posted by racear*2865 View Post
    racear
    racear*2865,
    There are a couple of things that you might want to check:
    Have you measured the voltages betwen T1, T2 and T3?
    If one voltage is out by greater than 10%, consider swaping the motor leads with T1, T2 and T3 until you get a better balance.
    That is :
    Motor leads:
    1-7----------------2-8----------------3-9
    T1-----voltage-----T2-----voltage-----T3-----voltage to T1
    T1-----voltage-----T3-----voltage-----T2-----voltage to T1
    T2-----voltage-----T3-----voltage-----T1-----voltage to T2
    (note: make sure that you id the new wild leg wire)
    If that doesnt work, google the Fitch Williams RPC on usenet and
    try adding additional capacitors as outlined in the post(s) to balance
    the voltages. Be careful, charged caps can bite even when removed from
    current for a long time.
    If the machine is over 50 feet away from the RPC, consider increasing the
    feed wires to a size or two larger. That is, if you are running #6, go to a #4.
    Finally, a last resort would be to add an additional 10hp idler or consider a voltage stabilizer transformer.
    be safe.
    regards,
    Jim
    1. Who makes the best rotary phase converter?
      By DF-ENTERPRISES in forum Phase Converters and VFD
      Last Post: 12-01-2010, 01:22 AM
    2. running off rotary phase converter
      By Joe Miranda in forum Milltronics
      Last Post: 04-14-2008, 10:19 AM
    3. 760-22 with rotary phase converter?
      By tstom in forum Bridgeport and Hardinge Mills
      Last Post: 03-03-2008, 01:34 PM
    4. Re: Rotary Phase Converter - Deckel
      By T_Rex in forum Deckel, Maho, Aciera, Abene Mills
      Last Post: 06-25-2007, 04:48 PM
    5. HELP rotary converter for air compressor
      By gman1487 in forum General Electronics Discussion
      Last Post: 06-04-2007, 12:22 AM
